ميزة الأسئلة والأجوبة من Google
We are working on a Question/Answer type community and have a question related SEO. It appears that Google is ranking websites that follow their Q&A SEO feature very high for anyone that is asking a similar or exact question. You can see this feature here.
Now, if you look at the markup it appears to require custom JavaScript on the actual page that the Question and Answer is on. Since Discourse doesn’t support JavaScript being placed in the actual posts (rightfully so, as that could be dangerous), is there a way to get this working with something like a plugin? If so, I think this would be a great plugin request as it could benefit anyone using discourse for Q&A discussions.
Thanks,
Kasey A.
This is already supported with the Solved plugin. See Support schema.org QAPage and Google rich results for details.
5 إعجابات
