It looks like discourse spits out custom Nginx logs. There wouldn’t happen to be a grok pattern for those logs anywhere? I looked and was unable to find anything.
I’m not aware of one. We haven’t written one ourselves because we collect all access log data through haproxy.
We have this ![]()
It is in ruby and probably easily portable to an elastic grok rule
Thanks for the pointer! I’ll drop this here for anyone looking:
I’m parsing the discourse logs with the telegraf logparser plugin. The following config works to parse this:
[[inputs.logparser]]
files = [
"/var/discourse/shared/standalone/log/var-log/nginx/access.log",
"/var/discourse/shared/standalone/log/var-log/nginx/access.log.1"
from_beginning = true
[inputs.logparser.grok]
measurement="nginx_access"
patterns=[
'''\[%{CUSTOM_TIMESTAMP:timestamp:ts-httpd}\] %{IP:client_ip} "%{NOTSPACE:method:tag} %{NOTSPACE:request_path} %{NOTSPACE:http_version}" "%{DATA:user_agent}" "%{DATA:discourse_route:tag}" %{NUMBER:response_code:tag} %{NUMBER:resp_bytes:int} "%{DATA:x_referrer}" %{NUMBER} %{NUMBER:resp_time:float} "%{DATA:username:tag}"'''
custom_patterns = '''
CUSTOM_TIMESTAMP %{MONTHDAY}/%{MONTH}/%{YEAR}:%{HOUR}:%{MINUTE}:%{SECOND} %{CUSTOM_TZ}
CUSTOM_TZ [+-][0-9]{4}
The data is as follows in InfluxDB line protocol:
measurement: nginx_access,
tags: [
method,
discourse_route,
response_code,
username
fields: {
client_ip: string,
request_path: string,
http_version: string,
user_agent: string,
resp_bytes: int,
x_referer: string,
resp_time: float,
