Hi everyone!
I’ve been working on setting up a multi-site Discourse instance, and while I’ve made some progress, I’m running into a few roadblocks and could really use some guidance from someone. I’ve gone through the Multisite configuration with Docker guide, but I still have a few questions:
- Where can I find the “multisite.yml” file that’s mentioned? I don’t see it in my
discourse/templatesfolder. - Do I need to set up hooks for
after_postgreseven if I’m just using the standard volume and not a dedicated database? - Is there a simple
app.ymltemplate for a basic multi-site setup? I’m not looking to add plugins or anything fancy—just something straightforward to get started.
For context, I’m currently running a standard Discourse instance on a GCP VM, accessible via mamacares. My app.yml is pretty much the default—no plugins or dedicated database. If anyone has experience with this or knows of a quick start guide for setting up a multi-site configuration, I’d really appreciate the help!
This is my current app.yml for reference (I removed the sensitive data)
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
## Uncomment the next line to enable the IPv6 listener
#- "templates/web.ipv6.template.yml"
#- "templates/web.ssl.template.yml"
#- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
- "80:80" # http
- "443:443" # https
params:
db_shared_buffers: "256MB"
#db_work_mem: "40MB"
#version: tests-passed
env:
LC_ALL: en_US.UTF-8
LANG: en_US.UTF-8
LANGUAGE: en_US.UTF-8
UNICORN_WORKERS: 4
## Required. Discourse will not work with a bare IP number.
DISCOURSE_HOSTNAME: 'www.mamacares.com'
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
#DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: '---------'
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: ----------
#DISCOURSE_SMTP_PORT: --------
DISCOURSE_SMTP_USER_NAME: ----------
DISCOURSE_SMTP_PASSWORD: ------------
#DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
#DISCOURSE_SMTP_DOMAIN: discourse.example.com # (required by some providers)
#DISCOURSE_NOTIFICATION_EMAIL: noreply@discourse.example.com # (address to send notifications from)
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
#LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
## The http or https CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
## The maxmind geolocation IP account ID and license key for IP address lookups
## see https://meta.discourse.org/t/-/173941 for details
#DISCOURSE_MAXMIND_ACCOUNT_ID: 123456
#DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
## Plugins go here
hooks:
after_postgres:
- exec: sudo -u postgres createdb b_discourse || exit 0
- exec:
stdin: |
grant all privileges on database b_discourse to discourse;
cmd: sudo -u postgres psql b_discourse
raise_on_fail: false
- exec: /bin/bash -c 'sudo -u postgres psql b_discourse <<< "alter schema public
owner to discourse;"'
- exec: /bin/bash -c 'sudo -u postgres psql b_discourse <<< "create extension if
not exists hstore;"'
not exists pg_trgm;"'
after_code:
- exec:
cd: $home/plugins
cmd:
- mkdir -p plugins
before_bundle_exec:
- file:
path: $home/config/multisite.yml
contents: |
secondsite:
adapter: postgresql
database: b_discourse
pool: 25
timeout: 5000
db_id: 2
host_names:
#- www.mamacares.com
- www.vet.community
after_bundle_exec:
- exec: cd /var/www/discourse && sudo -E -u discourse bundle exec rake multisite:migrate
run:
Thanks so much, and looking forward to any advice you can share!
