Handling old accounts that have changed emails?
If you visited a Discourse a long time ago, and no longer control the email address your account was originally created under – how can we get that user back into their account?
I guess there are two options here:
  1. You don’t remember which email it was, and you don’t control that email address any more
  2. You do remember which email it was, and you don’t control that email address any more
So you’d issue a standard forgot password request …
I guess the only option here is to contact staff out-of-band via the /about page email address and ask them to change the email on the account? This is extra tricky if you don’t remember the email address you signed up with – how does this other user prove that they are, in fact, the person who originally controlled the old email account?
I wonder how we can provide information / assistance to the user on these two dialogs to handle this rare, but highly unfortunate, scenario without it being TL;DR for everyone else.
Maybe a small link to the staff page on this dialog makes sense to handle that and other unusual login scenarios where staff intervention is inevitable and required. Or perhaps a “help” button on this dialog, so that way we’re not smacking every workaday “forgot my password again” user with a bunch of extraneous information that is only useful in these rare cases?
「いいね!」 5
Maybe it would be helpful to reveal some characters of the email. perhaps 3 characters? I see many big businesses do it.
we found username example and sent an email to nam*@example.com** , …
「いいね!」 6
OK! @techapj added this help feature and I will use this copy for it:
Email not arriving? Be sure to check your spam folder first.
Not sure which email address you used? Enter an email address and we’ll let you know if it exists here.
If you no longer have access to the email address on your account, please contact our helpful staff.
「いいね!」 4
管理者がユーザーのメールアドレスを変更した場合、ユーザーはその新しいメールアドレスを確認する必要がありますが、古いメールアドレスには変更の通知が行かない、という理解で正しいでしょうか?
悪意のある第三者が他のユーザーのアカウントを乗っ取る影響を少なくとも軽減する方法の一つとして、スタッフがメールアドレスの変更をトリガーした場合、新しいメールアドレスに変更が行われたことを古いメールアドレスにも通知することが考えられます。
最後に簡単な質問です:この場合、新しいメールアドレスはいつから有効になるのでしょうか?即時でしょうか、それとも新しいメールアドレスが確認された後でしょうか?後者だと推測していますが、確認させてください。
「いいね!」 1
現在、2 つのメールアドレス変更のうち 1 つで、notify_old_email が実際に送信されていることに気づきました。そのメールに対応するテンプレートは見つかりませんでしたが、このメールは事後的に、つまり新しいメールアドレスが確認された後に送信されているのではないかと推測しています。その認識で合っていますか?
これはスタッフアカウントにのみ当てはまります。セキュリティを強化するため、スタッフユーザーは古いメールアドレスと新しいメールアドレスの両方を確認する必要があります。
(もし何らかの理由で古いメールアドレスの管理権限を失っている場合、これは不可能になります。ただし、このルールはスタッフにのみ適用されるため、そのような状況に直面することは稀であるはずです。)
