The discussion revolves around determining the minimum hardware requirements to run Discourse for a community of ~3,000 developers. jcayzac is seeking specific guidance on the number of Redis and Postgres nodes, cores, RAM, and disk size needed for the Discourse node.
pfaffman responds that the question is difficult to answer due to the variability in user activity and suggests starting with a baseline setup (e.g., 2GB RAM) and scaling up as needed. Discourse setup guidelines automatically adjust settings based on available RAM, regardless of the number of containers.
codinghorror agrees with pfaffman and recommends starting simply and scaling as needed, while also emphasizing the importance of setting up a Content Delivery Network (CDN) to alleviate load and improve user experience.
I’m having a hard time finding hardware requirements except for the all-in-one standalone version of Discourse running Postgres and Redis on the same machine (and even for the standalone version, the requirements are vague: what do I need 1GB of RAM for? 1 daily active user? 10,000 daily active users?).
Could someone help me evaluate the minimum I need to run Discourse for a community of ~3,000 developers with proper fault tolerance and guaranteed SLAs? Especially:
3000 developers doing what? Are they all online at once? Are they each creating 100 posts per day and view 1000 posts each or do they visit every other day and read 5 posts? Are you using CDN? S3 for uploads? The reason that your question isn’t answered anywhere is that it’s to hard to ask your question in a way that it has an answer.
There are guidelines for those settings depending on how much ram you have that get set automatically by Discourse setup. It’s the same for two containers as for one.
Mostly, you start with 2gb or whatever you think you can afford and increase it if you see that you have a problem.
Yes, I recommend starting out simply and scaling as you observe the need.
(For anything except the smallest Discourse instances, I would recommend starting with a CDN setup, though… it does alleviate a fair bit of load and it’s a better experience for your users.)
