Is anyone running Discourse on AWS’s new EC2 Container Service? Is it recommendable? Are there any known issues with managing them?
Thanks
And a little bit longer… ;oP
Thanks
It doesn’t work, because of a couple reasons:
Any update/improvement on this, two years later?
Or will this never ever work at all with EC2 Container Services?
not sure about container service but I am running discourse under docker along with a side on wordpress(non-dockerised) and not facing issues managing them. as it is being reverse-proxied by nginx to the discourse container.
so everything is organised.
A container service manages docker and the base OS for you AFAIK. You don’t have root access. You just throw a container in and the service runs it.
Discourse requires root access to config.
but on EC2 you do have root access.
As OP said discourse doesn’t work on ECS. I wonder why? even when you have root access.
AFAIK, ECS is simply EC2 running docker for you. so, I wonder why it cannot run discourse on ECS. whilst I am running discourse on EC2.
PS: don’t mind If I am wrong. I don’t know much about ECS
ECS takes away the OS and decker management from you. For example they manage all the upgrades and patches. You dont have to do those. So it is not a complete VM. It is a managed service. You only provide a container.
This way it’s impossible to run discourse on ECS. since discourse needs to be root
Can you explain why? Is there any post at meta that’s linked on this topic?
It will work fine on Ecs , bootstrap an image push to registry and then specify env and volumes
as sam confirms above, it should work on ecs.
That’s right. I suppose the container must be prebuilt outside for the exact config then thrown into ECS.
will try that and possibly write a thorough article for more people to come
Thanks sam
A lot of config can be provided via env on a bootstrapped image, majority of it
