MailgunからGmailへの送信に問題が発生しています
Hello everyone. :slight_smile:
I’ve recently installed a Discourse instance to serve the community purposes of my website. And used Mailgun’s SMTP credentials for emailing. Setup goes fine, and I received the setup email on my GMX adress.
But after I’ve tried to send private invites to my closest friends, it appears Gmail adresses aren’t received emails. It works for hotmail, yahoo, GMX, and all others major platforms, but not Gmail.
For your information, I use Mailgun’s API with Mailgun WordPress extension to manage emailing from my webzine. Totally works fine, even for Gmail adresses.
So why it doesn’t work with SMTP credentials in Discourse ? And why only with Gmail adresses ? Does someone have a hint or any idea about this ?
I really need to fix this issue, I don’t want to lose 30% of potential subscriptions because of this problem.
Thanks ! :slight_smile:
Mailgun absolutely works with Discourse routing to Gmail, it’s one of the most common configurations.
Do you have a g suite account on the same domain? Does discourse route from a separate subdomain, or one which has MX records configured for inbound mail relay to another provider?
This is very likely to be DNS related.
I’d check your logs but in discourse and mailgun and open a ticket with them. You should check that the domain name you are sending from is one that Mailgun has activated.
Problem fixed. It was a simple problem with DMARC security protocol : the sending email adress needs to match with the domain registered in Mailgun. Thanks ! :slight_smile:
