Having trouble getting the site up after update
Vinoth_Deivasigamani encountered an issue after updating Discourse via the GUI, which failed. They then attempted a command-line update using ./launcher rebuild app, followed by start and restart, but the site remained unreachable with a ‘This site can’t be reached’ error. Logs showed services like Redis, PostgreSQL, and Unicorn starting and shutting down repeatedly, suggesting instability. Despite not understanding the root cause, Vinoth_Deivasigamani resolved the issue by rerunning ./launcher rebuild app, after which the site unexpectedly came back online. The user expressed relief but admitted confusion over what initially went wrong.
Update from GUI failed. So I did a commandline update by doing the following:
cd /var/discourse
When I try to connect to the site from the browser, I get ‘This site can’t be reached’ error. Thinking that maybe the container has not started, I tried
./launcher start app
I get a message saying that the container has already started. I did the following for good measure:
./launcher restart app
Still the same problem. The site remains unreachable from browser. I’m not very familiar with docker or discourse. So not even sure where to begin debugging.
This is what I get when I do
./launcher logs app
x86_64 arch detected.
WARNING: containers/app.yml file is world-readable. You can secure this file by running: chmod o-rwx containers/app.yml
run-parts: executing /etc/runit/1.d/00-fix-var-logs
run-parts: executing /etc/runit/1.d/anacron
run-parts: executing /etc/runit/1.d/cleanup-pids
Cleaning stale PID files
run-parts: executing /etc/runit/1.d/copy-env
Started runsvdir, PID is 28
ok: run: redis: (pid 40) 0s
ok: run: postgres: (pid 36) 0s
supervisor pid: 38 unicorn pid: 67
Shutting Down
run-parts: executing /etc/runit/3.d/01-nginx
ok: down: nginx: 0s, normally up
run-parts: executing /etc/runit/3.d/02-unicorn
(38) exiting
ok: down: unicorn: 0s, normally up
run-parts: executing /etc/runit/3.d/10-redis
ok: down: redis: 1s, normally up
run-parts: executing /etc/runit/3.d/99-postgres
ok: down: postgres: 0s, normally up
ok: down: cron: 1s, normally up
ok: down: nginx: 8s, normally up
ok: down: postgres: 1s, normally up
ok: down: redis: 8s, normally up
ok: down: rsyslog: 0s, normally up
ok: down: unicorn: 8s, normally up
ok: run: redis: (pid 43) 1s
ok: run: postgres: (pid 37) 1s
supervisor pid: 35 unicorn pid: 67
I would appreciate if somebody could help me get the site up again.
On a whim, I reran:
It started working again. I have no idea what went wrong before. But I’m glad it healed.
