Help deploying older versions of Discourse
There should be an error here, I tried to pull v3.6.0.beta2 via a tag, but encountered the following error:
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  git fetch --tags --prune-tags --prune --force origin
  if [[ $(git symbolic-ref --short HEAD) == v3.6.0.beta2 ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout v3.6.0.beta2
  fi
' failed with return #<Process::Status: pid 146 exit 128>
Location of failure: /usr/local/lib/ruby/gems/3.4.0/gems/pups-1.4.0/lib/pups/exec_command.rb:138:in `Pups::ExecCommand#spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"code", "cmd'=>["sudo -H -E -u discourse git clean -f", "sudo -H -E -u discourse bash -c '\\n  set -o errexit\\n  git fetch --tags --prune-tags --prune --force origin\\n  if [[ $(git symbolic-ref --short HEAD) == $version ]] ; then\\n      git pull\\n  else\\n      git -c advice.detachedHead=false checkout $version\\n  fi\\n'", "sudo -H -E -u discourse git config user.discourse-version $version", "mkdir -p tmp", "chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets", "touch tmp/.gitkeep", "mkdir -p                    /shared/log/rails", "bash -c \\"touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\\"", "bash -c \\"ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\\"", "bash -c \\"mkdir -p           /shared/{uploads,backups}\\"", "bash -c \\"ln    -s           /shared/{uploads,backups} $home/public\\"", "bash -c \\"mkdir -p           /shared/tmp/{backups,restores}\\"", "bash -c \\"ln    -s           /shared/tmp/{backups,restores} $home/tmp\\"", "chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp", "[ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete"]}
bootstrap failed with exit code 128
adc8ef45e9ae880827c9294dbbf73dfe9ab413a050c83fe3f4722c2911876ce2
version only supports branches, not tags!
What is correct is:
params:
  version: release/2025.11
As for why I want to pull release/2025.11, it’s because the current production environment is on a version close to that, and I want to upgrade, but I’m afraid of potential issues. Furthermore, the audit process does not allow me to perform upgrades directly; I must first validate the upgrade process (from release/2025.11 to release/2026.1) in the test environment before proceeding in production. Although this is somewhat tedious, it is indeed the best choice for a correct process. Thus, I had to look for a way to pull a specific branch or tag here.
Sorry for saying so much unnecessary stuff. Fortunately, I have now found a passable solution. Thank you everyone.
I continue to update on other impacts caused by this modification:
Installing a specific branch was successful, but attempting to verify an upgrade from this branch failed. This is because the latest update is not detected on the update page, preventing the update operation from being performed on the page.
Continuing from the previous topic, a new issue has been identified. When the local codebase is outdated, it can cause frontend compilation failures or other errors. Therefore, before making any modifications, the local codebase must be updated to the latest version.
# If you have previously modified the local codebase, please stash your changes first
# git stash
# Update to the latest version
git pull
# Reapply the stashed changes, or re-edit the corresponding configuration files
# git stash pop
Only after updating the local repository to the latest version can the installation proceed smoothly to build the specified branch as per the previous steps.
The local codebase referred to here is: https://github.com/discourse/discourse_docker.git
That is, the codebase after a standard installation.
Finally, here is a summary.
Our requirement is: install a specific version.
  1. Update the local code repository https://github.com/discourse/discourse_docker.git
# Enter the project root directory
cd /var/discourse
git pull
  1. Modify the version to be specified
Edit containers/app.yml and add the following configuration at the end:
params:
  version: release/2026.1 # Best practice should be: esr
  1. Rebuild
./launcher rebuild app
If version: esr, you don’t need to read further.
First, run git pull to ensure the local code repository is up to date. Then specify the branch to deploy, and finally rebuild. This instruction applies to scenarios where you want to upgrade from release/2026.1 to release/2026.7.
If you simply want to upgrade an already installed release/2026.1, you should just click “Upgrade” in the admin dashboard. This applies to scenarios where release/2026.1 has updates (especially security fixes).
I think it would be very unusual to configure a specific version, rather than a flavour/stream/tag, like latest or stable. I’m actually no longer sure what tags are normal and available and useful with this system.
Have you taken a look at Configure a supported tracking branch to get Discourse software updates ? Maybe it helps for understanding which tags are useful
Yes, for ordinary users, the default latest is sufficient. However, for my scenario, I have no choice but to investigate how to use a specific version. I can’t just tell the boss: “Oh, I’m sorry, Discourse doesn’t currently support checking out a specific version; we can only update to the latest version.”
This post is very helpful; I will take a careful look at it. Thank you.
I hadn’t seen that - thanks. Looks like we should be using latest/release/esr now. I see my own (old) app.yml picks up the default by being commented out:
  #version: tests-passed
version currently does not support tags. To add support, the build script must be modified. The best practice would originally be:
params:
  version: esr
However, currently, it must be changed to:
params:
Interesting. Even before the new versioning strategy, beta had been a tag instead of a branch for quite a while: Upcoming changes to the beta branch of Discourse
It’s me, I’m also confused, but the current build code indeed cannot use tags. This shouldn’t be the case.
version: release/2026.1 should work fine. If you want to take advantage of the new overlapping support periods on versions, then this is the correct way to do it. (but of course, you must to remember to update manually before 2026.1 reaches its end-of-life)
version: esr should also work. The system is designed to support tags. It is implemented as git checkout $version.
You should not make this change in web.template.yml. You should make it in your site-specific containers/app.yml
Something doesn’t appear to be right here. I was running v3.5.0 beta3 with the yml set to version: tests-passed
Then I noticed this versioning change so before rebuilding I changed the yml to version: esr and then did a rebuild from the CLI.
Now in discourse I see
Installed
2026.3.0-latest.1
This appears to be using the tests passed tag instead of the esr tag. I verified that app.yml is showing the version as esr , so why it it grabbing the latest build ?
So essentially there’s no way to get the most recent stable / esr build anymore?
Can you share the relevant lines of the app.yml file. Is version: definitely indented underneath the params: section? And have you definitely removed the # YAML comment character from the beginning of the line?
Just FYI, if you do want to get back onto ESR, you’ll need to either restore an earlier backup, or wait until the next ESR release in July. Downgrading a discourse installation is not supported :cry:
Yes am aware that I cannot downgrade. Attaching a screenshot showing the indentation.
Notice anything wrong here?
I believe version should be indented because it’s part of params.
Yes, I initially configured it directly in containers/app.yml, but for some reason, it didn’t take effect. Out of necessity, I ended up modifying templates/web.template.yml directly. I will try modifying containers/app.yml again.
Additionally, could you check why configuring version: esr does not take effect? Is this an isolated issue on my end, or is it a common occurrence? My network environment is indeed quite poor.
Configuration is as follows:
params:
  version: v3.6.0.beta2
The error message is:
FAILED
  set -o errexit
      git pull
  else
  fi
Location of failure: /usr/local/lib/ruby/gems/3.4.0/gems/pups-1.4.0/lib/pups/exec_command.rb:138:in 'Pups::ExecCommand#spawn'
exec failed with the params {"cd" => "$home", "hook" => "code", "cmd" => ["sudo -H -E -u discourse git clean -f", "sudo -H -E -u discourse bash -c '\n  set -o errexit\n  git fetch --tags --prune-tags --prune --force origin\n  if [[ $(git symbolic-ref --short HEAD) == $version ]] ; then\n      git pull\n  else\n      git -c advice.detachedHead=false checkout $version\n  fi\n'", "sudo -H -E -u discourse git config user.discourse-version $version", "mkdir -p tmp", "chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets", "touch tmp/.gitkeep", "mkdir -p                    /shared/log/rails", "bash -c \"touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\"", "bash -c \"ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\"", "bash -c \"mkdir -p           /shared/{uploads,backups}\"", "bash -c \"ln    -s           /shared/{uploads,backups} $home/public\"", "bash -c \"mkdir -p           /shared/tmp/{backups,restores}\"", "bash -c \"ln    -s           /shared/tmp/{backups,restores} $home/tmp\"", "chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp", "[ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete"]}
The root cause is that the git symbolic-ref --short HEAD command can only return the branch name.
