Ajuda, erro de reconstrução
Ocorreu um erro na minha atualização
DISCOURSE DOCTOR Tue 08 Feb 2022 12:55:57 AM CST
OS: Linux vps.magentochina.org 4.19.0-6-amd64 #1 SMP Debian 4.19.67-2+deb10u2 (2019-11-11) x86_64 GNU/Linux
Found containers/app.yml
==================== YML SETTINGS ====================
DISCOURSE_HOSTNAME=forum.magentochina.org
SMTP_ADDRESS=smtp.office365.com # required
DEVELOPER_EMAILS=REDACTED
SMTP_PASSWORD=REDACTED  # required, WARNING the char '#' in pw can cause problems!
SMTP_PORT=587 # (optional, default 587)
SMTP_USER_NAME=service@magentochina.org # required
LETSENCRYPT_ACCOUNT_EMAIL=REDACTED
==================== DOCKER INFO ====================
DOCKER VERSION: Docker version 18.09.1, build 4c52b90
DOCKER PROCESSES (docker ps -a)
CONTAINER ID        IMAGE                 COMMAND             CREATED             STATUS                   PORTS               NAMES
23b09c56e033        local_discourse/app   "/sbin/boot"        5 weeks ago         Exited (5) 8 hours ago                       app
==================== SERIOUS PROBLEM!!!! ====================
app not running!
Attempting to rebuild
==================== REBUILD LOG ====================
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
/usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2022-02-07T16:56:10.490923 #1]  INFO -- : Reading from stdin
I, [2022-02-07T16:56:10.502085 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2022-02-07T16:56:10.570410 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2022-02-07T16:56:10.570681 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2022-02-07T16:56:10.575255 #1]  INFO -- :
I, [2022-02-07T16:56:10.575481 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2022-02-07T16:56:10.579690 #1]  INFO -- :
I, [2022-02-07T16:56:10.579919 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2022-02-07T16:56:10.584073 #1]  INFO -- :
I, [2022-02-07T16:56:10.584309 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2022-02-07T16:56:10.588674 #1]  INFO -- :
I, [2022-02-07T16:56:10.588907 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2022-02-07T16:56:10.592506 #1]  INFO -- :
I, [2022-02-07T16:56:10.592741 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2022/02/07 16:56:10 socat[18] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2022-02-07T16:56:10.600782 #1]  INFO -- :
I, [2022-02-07T16:56:10.600999 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2022-02-07T16:56:10.605737 #1]  INFO -- :
I, [2022-02-07T16:56:10.605978 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2022-02-07T16:56:10.610654 #1]  INFO -- :
I, [2022-02-07T16:56:10.610896 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2022-02-07T16:56:10.615014 #1]  INFO -- :
I, [2022-02-07T16:56:10.615264 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2022-02-07T16:56:10.619231 #1]  INFO -- :
I, [2022-02-07T16:56:10.628220 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2022-02-07T16:56:10.636377 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2022-02-07T16:56:10.644619 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2022-02-07T16:56:10.652746 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2022-02-07T16:56:10.653155 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2022-02-07T16:56:11.624914 #1]  INFO -- :
I, [2022-02-07T16:56:11.625476 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2022-02-07T16:56:11.629721 #1]  INFO -- :
I, [2022-02-07T16:56:11.629921 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2022-02-07T16:56:11.664491 #1]  INFO -- :
I, [2022-02-07T16:56:11.664784 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2022-02-07T16:56:11.669565 #1]  INFO -- :
I, [2022-02-07T16:56:11.670029 #1]  INFO -- : > /root/upgrade_postgres
I, [2022-02-07T16:56:11.677609 #1]  INFO -- :
I, [2022-02-07T16:56:11.677816 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2022-02-07T16:56:11.681543 #1]  INFO -- :
I, [2022-02-07T16:56:11.682289 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2022-02-07T16:56:11.683107 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2022-02-07T16:56:11.683723 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2022-02-07T16:56:11.684267 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2022-02-07T16:56:11.684821 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2022-02-07T16:56:11.685353 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2022-02-07T16:56:11.685843 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2022-02-07T16:56:11.690831 #1]  INFO -- :
I, [2022-02-07T16:56:11.691470 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2022-02-07T16:56:11.692077 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2022-02-07T16:56:11.692633 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2022-02-07T16:56:11.693226 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2022-02-07T16:56:11.693722 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2022-02-07T16:56:11.694207 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2022-02-07T16:56:11.694655 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2022-02-07T16:56:11.698298 #1]  INFO -- : > sleep 5
2022-02-07 16:56:11.854 UTC [41] LOG:  starting PostgreSQL 13.5 (Debian 13.5-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2022-02-07 16:56:11.854 UTC [41] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2022-02-07 16:56:11.854 UTC [41] LOG:  listening on IPv6 address "::", port 5432
2022-02-07 16:56:11.856 UTC [41] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2022-02-07 16:56:11.861 UTC [44] LOG:  database system was shut down at 2022-02-07 16:53:56 UTC
2022-02-07 16:56:11.869 UTC [41] LOG:  database system is ready to accept connections
I, [2022-02-07T16:56:16.703484 #1]  INFO -- :
I, [2022-02-07T16:56:16.703896 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2022-02-07 16:56:16.820 UTC [54] postgres@postgres ERROR:  database "discourse" already exists
2022-02-07 16:56:16.820 UTC [54] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2022-02-07T16:56:16.822458 #1]  INFO -- :
I, [2022-02-07T16:56:16.823004 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2022-02-07 16:56:16.927 UTC [58] postgres@discourse ERROR:  role "discourse" already exists
2022-02-07 16:56:16.927 UTC [58] postgres@discourse STATEMENT:  create user discourse;
I, [2022-02-07T16:56:16.930406 #1]  INFO -- :
I, [2022-02-07T16:56:16.931027 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2022-02-07T16:56:17.027169 #1]  INFO -- : GRANT
I, [2022-02-07T16:56:17.027680 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2022-02-07T16:56:17.116118 #1]  INFO -- : ALTER SCHEMA
I, [2022-02-07T16:56:17.116589 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2022-02-07T16:56:17.215723 #1]  INFO -- : CREATE EXTENSION
I, [2022-02-07T16:56:17.216096 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2022-02-07T16:56:17.306996 #1]  INFO -- : CREATE EXTENSION
I, [2022-02-07T16:56:17.307742 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2022-02-07T16:56:17.398758 #1]  INFO -- : CREATE EXTENSION
I, [2022-02-07T16:56:17.399473 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2022-02-07T16:56:17.489038 #1]  INFO -- : CREATE EXTENSION
I, [2022-02-07T16:56:17.489800 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2022-02-07T16:56:17.494420 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2022-02-07T16:56:17.602512 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2022-02-07T16:56:17.607973 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2022-02-07T16:56:17.608159 #1]  INFO -- : > echo postgres installed!
I, [2022-02-07T16:56:17.611868 #1]  INFO -- : postgres installed!
I, [2022-02-07T16:56:17.619987 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2022-02-07T16:56:17.628951 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2022-02-07T16:56:17.637234 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2022-02-07T16:56:17.637993 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2022-02-07T16:56:17.638788 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2022-02-07T16:56:17.639362 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2022-02-07T16:56:17.644438 #1]  INFO -- :
I, [2022-02-07T16:56:17.644867 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2022-02-07T16:56:17.645616 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2022-02-07T16:56:17.646384 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2022-02-07T16:56:17.647139 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2022-02-07T16:56:17.647747 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2022-02-07T16:56:17.648283 #1]  INFO -- : > echo redis installed
I, [2022-02-07T16:56:17.652202 #1]  INFO -- : redis installed
I, [2022-02-07T16:56:17.652420 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2022-02-07T16:56:17.660386 #1]  INFO -- : logfile ""
I, [2022-02-07T16:56:17.660665 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2022-02-07T16:56:17.663978 #1]  INFO -- : > sleep 10
102:C 07 Feb 2022 16:56:17.670 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
102:C 07 Feb 2022 16:56:17.670 # Redis version=6.2.6, bits=64, commit=00000000, modified=0, pid=102, just started
102:C 07 Feb 2022 16:56:17.670 # Configuration loaded
102:M 07 Feb 2022 16:56:17.671 * monotonic clock: POSIX clock_gettime
102:M 07 Feb 2022 16:56:17.671 * Running mode=standalone, port=6379.
102:M 07 Feb 2022 16:56:17.672 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
102:M 07 Feb 2022 16:56:17.672 # Server initialized
102:M 07 Feb 2022 16:56:17.672 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
102:M 07 Feb 2022 16:56:17.672 * Loading RDB produced by version 6.2.6
102:M 07 Feb 2022 16:56:17.672 * RDB age 141 seconds
102:M 07 Feb 2022 16:56:17.672 * RDB memory usage when created 4.02 Mb
102:M 07 Feb 2022 16:56:17.692 # Done loading RDB, keys loaded: 6576, keys expired: 0.
102:M 07 Feb 2022 16:56:17.692 * DB loaded from disk: 0.020 seconds
102:M 07 Feb 2022 16:56:17.692 * Ready to accept connections
I, [2022-02-07T16:56:27.668525 #1]  INFO -- :
I, [2022-02-07T16:56:27.669091 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2022-02-07T16:56:27.675954 #1]  INFO -- : thpoff is installed!
I, [2022-02-07T16:56:27.676326 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2022-02-07T16:56:27.853955 #1]  INFO -- :
I, [2022-02-07T16:56:27.854515 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2022-02-07T16:56:27.978529 #1]  INFO -- :
I, [2022-02-07T16:56:27.978940 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2022-02-07T16:56:28.110513 #1]  INFO -- :
I, [2022-02-07T16:56:28.111114 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2022-02-07T16:56:28.116439 #1]  INFO -- :
I, [2022-02-07T16:56:28.122213 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2022-02-07T16:56:28.131535 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2022-02-07T16:56:28.140493 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2022-02-07T16:56:28.150000 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2022-02-07T16:56:28.159150 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2022-02-07T16:56:28.168896 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2022-02-07T16:56:28.169143 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2022-02-07T16:56:28.169579 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2022-02-07T16:56:28.173984 #1]  INFO -- : > cd /var/www/discourse && git reset --hard
130:C 07 Feb 2022 16:56:28.178 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
130:C 07 Feb 2022 16:56:28.178 # Redis version=6.2.6, bits=64, commit=00000000, modified=0, pid=130, just started
130:C 07 Feb 2022 16:56:28.178 # Configuration loaded
130:M 07 Feb 2022 16:56:28.179 * monotonic clock: POSIX clock_gettime
130:M 07 Feb 2022 16:56:28.179 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
130:M 07 Feb 2022 16:56:28.179 # Failed listening on port 6379 (TCP), aborting.
Updating files:  12% (3964/30947)
Updating files:  13% (4024/30947)
Updating files:  14% (4333/30947)
Updating files:  15% (4643/30947)
Updating files:  16% (4952/30947)
Updating files:  17% (5261/30947)
Updating files:  18% (5571/30947)
Updating files:  19% (5880/30947)
Updating files:  20% (6190/30947)
Updating files:  21% (6499/30947)
Updating files:  22% (6809/30947)
Updating files:  23% (7118/30947)
Updating files:  24% (7428/30947)
Updating files:  25% (7737/30947)
Updating files:  26% (8047/30947)
Updating files:  27% (8356/30947)
Updating files:  27% (8550/30947)
Updating files:  28% (8666/30947)
Updating files:  29% (8975/30947)
Updating files:  30% (9285/30947)
Updating files:  31% (9594/30947)
Updating files:  32% (9904/30947)
Updating files:  33% (10213/30947)
Updating files:  34% (10522/30947)
Updating files:  35% (10832/30947)
Updating files:  36% (11141/30947)
Updating files:  37% (11451/30947)
Updating files:  38% (11760/30947)
Updating files:  39% (12070/30947)
Updating files:  40% (12379/30947)
Updating files:  41% (12689/30947)
Updating files:  42% (12998/30947)
Updating files:  43% (13308/30947)
Updating files:  43% (13363/30947)
Updating files:  44% (13617/30947)
Updating files:  45% (13927/30947)
Updating files:  46% (14236/30947)
Updating files:  47% (14546/30947)
Updating files:  48% (14855/30947)
Updating files:  49% (15165/30947)
Updating files:  50% (15474/30947)
Updating files:  51% (15783/30947)
Updating files:  52% (16093/30947)
Updating files:  53% (16402/30947)
Updating files:  54% (16712/30947)
Updating files:  55% (17021/30947)
Updating files:  56% (17331/30947)
Updating files:  57% (17640/30947)
Updating files:  58% (17950/30947)
Updating files:  58% (18068/30947)
Updating files:  59% (18259/30947)
Updating files:  60% (18569/30947)
Updating files:  61% (18878/30947)
Updating files:  62% (19188/30947)
Updating files:  63% (19497/30947)
Updating files:  64% (19807/30947)
Updating files:  65% (20116/30947)
Updating files:  66% (20426/30947)
Updating files:  67% (20735/30947)
Updating files:  68% (21044/30947)
Updating files:  69% (21354/30947)
Updating files:  70% (21663/30947)
Updating files:  71% (21973/30947)
Updating files:  72% (22282/30947)
Updating files:  73% (22592/30947)
Updating files:  74% (22901/30947)
Updating files:  74% (22941/30947)
Updating files:  75% (23211/30947)
Updating files:  76% (23520/30947)
Updating files:  77% (23830/30947)
Updating files:  78% (24139/30947)
Updating files:  79% (24449/30947)
Updating files:  80% (24758/30947)
Updating files:  81% (25068/30947)
Updating files:  82% (25377/30947)
Updating files:  83% (25687/30947)
Updating files:  84% (25996/30947)
Updating files:  85% (26305/30947)
Updating files:  86% (26615/30947)
Updating files:  87% (26924/30947)
Updating files:  88% (27234/30947)
Updating files:  89% (27543/30947)
Updating files:  89% (27760/30947)
Updating files:  90% (27853/30947)
Updating files:  91% (28162/30947)
Updating files:  92% (28472/30947)
Updating files:  93% (28781/30947)
Updating files:  94% (29091/30947)
Updating files:  95% (29400/30947)
Updating files:  96% (29710/30947)
Updating files:  97% (30019/30947)
Updating files:  98% (30329/30947)
Updating files:  99% (30638/30947)
Updating files: 100% (30947/30947)
Updating files: 100% (30947/30947), done.
I, [2022-02-07T16:56:35.659636 #1]  INFO -- : HEAD is now at e1367cde I18N: Improve copy on blocked words error messages (#15741)
I, [2022-02-07T16:56:35.659857 #1]  INFO -- : > cd /var/www/discourse && git clean -f
I, [2022-02-07T16:56:35.872048 #1]  INFO -- :
I, [2022-02-07T16:56:35.872559 #1]  INFO -- : > cd /var/www/discourse && git remote set-branches --add origin main
I, [2022-02-07T16:56:35.880278 #1]  INFO -- :
I, [2022-02-07T16:56:35.880579 #1]  INFO -- : > cd /var/www/discourse && git remote set-branches origin stable
I, [2022-02-07T16:56:35.887166 #1]  INFO -- :
I, [2022-02-07T16:56:35.887516 #1]  INFO -- : > cd /var/www/discourse && git fetch --depth 1 origin stable
From https://github.com/discourse/discourse
 * branch              stable     -> FETCH_HEAD
 * [new branch]        stable     -> origin/stable
I, [2022-02-07T16:56:38.811245 #1]  INFO -- :
I, [2022-02-07T16:56:38.811504 #1]  INFO -- : > cd /var/www/discourse && git checkout stable
Switched to a new branch 'stable'
I, [2022-02-07T16:56:39.593966 #1]  INFO -- : Branch 'stable' set up to track remote branch 'stable' from 'origin'.
I, [2022-02-07T16:56:39.594165 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2022-02-07T16:56:39.601602 #1]  INFO -- :
I, [2022-02-07T16:56:39.601957 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2022-02-07T16:56:39.607437 #1]  INFO -- :
I, [2022-02-07T16:56:39.607669 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2022-02-07T16:56:39.613186 #1]  INFO -- :
I, [2022-02-07T16:56:39.613466 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2022-02-07T16:56:39.618783 #1]  INFO -- :
I, [2022-02-07T16:56:39.619026 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2022-02-07T16:56:39.624250 #1]  INFO -- :
I, [2022-02-07T16:56:39.624565 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2022-02-07T16:56:39.629728 #1]  INFO -- :
I, [2022-02-07T16:56:39.630046 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2022-02-07T16:56:39.637310 #1]  INFO -- :
I, [2022-02-07T16:56:39.637663 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2022-02-07T16:56:39.645297 #1]  INFO -- :
I, [2022-02-07T16:56:39.645698 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2022-02-07T16:56:39.653144 #1]  INFO -- :
I, [2022-02-07T16:56:39.653328 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2022-02-07T16:56:39.660834 #1]  INFO -- :
I, [2022-02-07T16:56:39.661099 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2022-02-07T16:56:39.669174 #1]  INFO -- :
I, [2022-02-07T16:56:39.669367 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2022-02-07T16:56:39.677011 #1]  INFO -- :
I, [2022-02-07T16:56:39.677217 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2022-02-07T16:56:39.708539 #1]  INFO -- :
I, [2022-02-07T16:56:39.708695 #1]  INFO -- : > cd /var/www/discourse && find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2022-02-07T16:56:39.715352 #1]  INFO -- :
I, [2022-02-07T16:56:39.715670 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2022-02-07T16:56:39.716972 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2022-02-07T16:56:43.421986 #1]  INFO -- :
I, [2022-02-07T16:56:43.422315 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/erickguan/discourse-chinese-localization-pack.git
Cloning into 'discourse-chinese-localization-pack'...
I, [2022-02-07T16:56:44.775335 #1]  INFO -- :
I, [2022-02-07T16:56:44.775676 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/onebox.git
Cloning into 'onebox'...
I, [2022-02-07T16:56:47.052128 #1]  INFO -- :
I, [2022-02-07T16:56:47.052466 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-github.git
Cloning into 'discourse-github'...
I, [2022-02-07T16:56:48.454641 #1]  INFO -- :
I, [2022-02-07T16:56:48.455058 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-solved.git
Cloning into 'discourse-solved'...
I, [2022-02-07T16:56:50.166482 #1]  INFO -- :
I, [2022-02-07T16:56:50.166772 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-signatures.git
Cloning into 'discourse-signatures'...
I, [2022-02-07T16:56:51.815666 #1]  INFO -- :
I, [2022-02-07T16:56:51.815964 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-sitemap.git
Cloning into 'discourse-sitemap'...
I, [2022-02-07T16:56:53.187606 #1]  INFO -- :
I, [2022-02-07T16:56:53.188050 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-translator.git
Cloning into 'discourse-translator'...
I, [2022-02-07T16:56:55.269133 #1]  INFO -- :
I, [2022-02-07T16:56:55.269507 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-adplugin.git
Cloning into 'discourse-adplugin'...
I, [2022-02-07T16:56:56.928045 #1]  INFO -- :
I, [2022-02-07T16:56:56.928617 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2022-02-07T16:56:56.935165 #1]  INFO -- :
I, [2022-02-07T16:56:56.935652 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2022-02-07T16:56:56.939868 #1]  INFO -- :
I, [2022-02-07T16:56:56.940276 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2022-02-07T16:56:56.944993 #1]  INFO -- :
I, [2022-02-07T16:56:56.945612 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2022-02-07T16:56:56.946154 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2022-02-07T16:56:56.946727 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2022-02-07T16:56:56.947363 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2022-02-07T16:56:56.947969 #1]  INFO -- : > echo "done configuring web"
I, [2022-02-07T16:56:56.951495 #1]  INFO -- : done configuring web
I, [2022-02-07T16:56:56.951942 #1]  INFO -- : > gem sources --add https://rubygems.org/
I, [2022-02-07T16:56:57.284610 #1]  INFO -- : source https://rubygems.org/ already present in the cache
I, [2022-02-07T16:56:57.285441 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2022-02-07T16:56:59.091598 #1]  INFO -- : Successfully installed bundler-2.3.4
1 gem installed
I, [2022-02-07T16:56:59.091873 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2022-02-07T16:57:04.090239 #1]  INFO -- :
I, [2022-02-07T16:57:04.090785 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
[DEPRECATED] A flag `--deployment` está obsoleta porque depende de ser lembrada entre invocações do bundler, o que o bundler não fará mais em versões futuras. Em vez disso, use `bundle config set --local deployment 'true'` e pare de usar esta flag
[DEPRECATED] A flag `--without` está obsoleta porque depende de ser lembrada entre invocações do bundler, o que o bundler não fará mais em versões futuras. Em vez disso, use `bundle config set --local without 'test development'` e pare de usar esta flag
I, [2022-02-07T16:57:06.913149 #1]  INFO -- : Executando `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` com bundler 2.3.4
Congelado, usando resolução do lockfile
Usando rake 13.0.6
0:  rake (13.0.6) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rake-13.0.6.gemspec
Usando concurrent-ruby 1.1.9
0:  concurrent-ruby (1.1.9) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/concurrent-ruby-1.1.9.gemspec
Usando i18n 1.8.11
0:  i18n (1.8.11) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/i18n-1.8.11.gemspec
Usando minitest 5.15.0
0:  minitest (5.15.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/minitest-5.15.0.gemspec
Usando tzinfo 2.0.4
0:  tzinfo (2.0.4) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tzinfo-2.0.4.gemspec
Usando zeitwerk 2.5.3
0:  zeitwerk (2.5.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/zeitwerk-2.5.3.gemspec
Usando activesupport 6.1.4.1
0:  activesupport (6.1.4.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activesupport-6.1.4.1.gemspec
Usando builder 3.2.4
0:  builder (3.2.4) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/builder-3.2.4.gemspec
Usando erubi 1.10.0
0:  erubi (1.10.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/erubi-1.10.0.gemspec
Usando racc 1.6.0
0:  racc (1.6.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/racc-1.6.0.gemspec
Usando nokogiri 1.12.5 (x86_64-linux)
0:  nokogiri (1.12.5) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nokogiri-1.12.5-x86_64-linux.gemspec
Usando rails-dom-testing 2.0.3
0:  rails-dom-testing (2.0.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-dom-testing-2.0.3.gemspec
Usando crass 1.0.6
0:  crass (1.0.6) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/crass-1.0.6.gemspec
Usando loofah 2.13.0
0:  loofah (2.13.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/loofah-2.13.0.gemspec
Usando rails-html-sanitizer 1.4.2
0:  rails-html-sanitizer (1.4.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-html-sanitizer-1.4.2.gemspec
Usando actionview 6.1.4.1
0:  actionview (6.1.4.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview-6.1.4.1.gemspec
Usando rack 2.2.3
0:  rack (2.2.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-2.2.3.gemspec
Usando rack-test 1.1.0
0:  rack-test (1.1.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-test-1.1.0.gemspec
Usando actionpack 6.1.4.1
0:  actionpack (6.1.4.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionpack-6.1.4.1.gemspec
Usando globalid 1.0.0
0:  globalid (1.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/globalid-1.0.0.gemspec
Usando activejob 6.1.4.1
0:  activejob (6.1.4.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activejob-6.1.4.1.gemspec
Usando mini_mime 1.1.2
0:  mini_mime (1.1.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_mime-1.1.2.gemspec
Usando mail 2.8.0.edge de https://github.com/discourse/mail.git
0:  mail (2.8.0.edge) de /var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/mail.gemspec
Usando actionmailer 6.1.4.1
0:  actionmailer (6.1.4.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionmailer-6.1.4.1.gemspec
Usando actionview_precompiler 0.2.3
0:  actionview_precompiler (0.2.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview_precompiler-0.2.3.gemspec
Usando activemodel 6.1.4.1
0:  activemodel (6.1.4.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activemodel-6.1.4.1.gemspec
Usando active_model_serializers 0.8.4
0:  active_model_serializers (0.8.4) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/active_model_serializers-0.8.4.gemspec
Usando activerecord 6.1.4.1
0:  activerecord (6.1.4.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activerecord-6.1.4.1.gemspec
Usando public_suffix 4.0.6
0:  public_suffix (4.0.6) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/public_suffix-4.0.6.gemspec
Usando addressable 2.8.0
0:  addressable (2.8.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/addressable-2.8.0.gemspec
Usando aws-eventstream 1.2.0
0:  aws-eventstream (1.2.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-eventstream-1.2.0.gemspec
Usando aws-partitions 1.516.0
0:  aws-partitions (1.516.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-partitions-1.516.0.gemspec
Usando aws-sigv4 1.4.0
0:  aws-sigv4 (1.4.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sigv4-1.4.0.gemspec
Usando jmespath 1.5.0
0:  jmespath (1.5.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jmespath-1.5.0.gemspec
Usando aws-sdk-core 3.121.2
0:  aws-sdk-core (3.121.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-core-3.121.2.gemspec
Usando aws-sdk-kms 1.44.0
0:  aws-sdk-kms (1.44.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-kms-1.44.0.gemspec
Usando aws-sdk-s3 1.96.1
0:  aws-sdk-s3 (1.96.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-s3-1.96.1.gemspec
Usando aws-sdk-sns 1.46.0
0:  aws-sdk-sns (1.46.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-sns-1.46.0.gemspec
Usando ember-source 2.18.2
0:  ember-source (2.18.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-source-2.18.2.gemspec
Usando execjs 2.8.1
0:  execjs (2.8.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/execjs-2.8.1.gemspec
Usando barber 0.12.2
0:  barber (0.12.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/barber-0.12.2.gemspec
Usando msgpack 1.4.2
0:  msgpack (1.4.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/msgpack-1.4.2.gemspec
Usando bootsnap 1.9.4
0:  bootsnap (1.9.4) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/bootsnap-1.9.4.gemspec
Usando bundler 2.3.4
0:  bundler (2.3.4) de /usr/local/lib/ruby/gems/2.7.0/specifications/bundler-2.3.4.gemspec
Usando byebug 11.1.3
0:  byebug (11.1.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/byebug-11.1.3.gemspec
Usando cbor 0.5.9.6
0:  cbor (0.5.9.6) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cbor-0.5.9.6.gemspec
Usando chunky_png 1.4.0
0:  chunky_png (1.4.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/chunky_png-1.4.0.gemspec
Usando coderay 1.1.3
0:  coderay (1.1.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/coderay-1.1.3.gemspec
Usando colored2 3.1.2
0:  colored2 (3.1.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/colored2-3.1.2.gemspec
Usando connection_pool 2.2.5
0:  connection_pool (2.2.5) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/connection_pool-2.2.5.gemspec
Usando ipaddr 1.2.3
0:  ipaddr (1.2.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ipaddr-1.2.3.gemspec
Usando openssl 2.2.1
0:  openssl (2.2.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-2.2.1.gemspec
Usando openssl-signature_algorithm 1.1.1
0:  openssl-signature_algorithm (1.1.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-signature_algorithm-1.1.1.gemspec
Usando cose 1.2.0
0:  cose (1.2.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cose-1.2.0.gemspec
Usando cppjieba_rb 0.3.3
0:  cppjieba_rb (0.3.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cppjieba_rb-0.3.3.gemspec
Usando css_parser 1.11.0
0:  css_parser (1.11.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/css_parser-1.11.0.gemspec
Usando diffy 3.4.0
0:  diffy (3.4.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/diffy-3.4.0.gemspec
Usando ember-data-source 3.0.2
0:  ember-data-source (3.0.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-data-source-3.0.2.gemspec
Usando sprockets 3.7.2
0:  sprockets (3.7.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-3.7.2.gemspec
Usando ember-handlebars-template 0.8.0
0:  ember-handlebars-template (0.8.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-handlebars-template-0.8.0.gemspec
Usando method_source 1.0.0
0:  method_source (1.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/method_source-1.0.0.gemspec
Usando thor 1.2.1
0:  thor (1.2.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/thor-1.2.1.gemspec
Usando railties 6.1.4.1
0:  railties (6.1.4.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/railties-6.1.4.1.gemspec
Usando jquery-rails 4.4.0
0:  jquery-rails (4.4.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jquery-rails-4.4.0.gemspec
Usando discourse-ember-rails 0.18.6
0:  discourse-ember-rails (0.18.6) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-rails-0.18.6.gemspec
Usando discourse-ember-source 3.12.2.3
0:  discourse-ember-source (3.12.2.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-source-3.12.2.3.gemspec
Usando discourse-fonts 0.0.9
0:  discourse-fonts (0.0.9) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-fonts-0.0.9.gemspec
Usando regexp_parser 2.2.0
0:  regexp_parser (2.2.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/regexp_parser-2.2.0.gemspec
Usando ecma-re-validator 0.4.0
0:  ecma-re-validator (0.4.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ecma-re-validator-0.4.0.gemspec
Usando email_reply_trimmer 0.1.13
0:  email_reply_trimmer (0.1.13) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/email_reply_trimmer-0.1.13.gemspec
Usando excon 0.89.0
0:  excon (0.89.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/excon-0.89.0.gemspec
Usando exifr 1.3.9
0:  exifr (1.3.9) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/exifr-1.3.9.gemspec
Usando faraday-em_http 1.0.0
0:  faraday-em_http (1.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_http-1.0.0.gemspec
Usando faraday-em_synchrony 1.0.0
0:  faraday-em_synchrony (1.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_synchrony-1.0.0.gemspec
Usando faraday-excon 1.1.0
0:  faraday-excon (1.1.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-excon-1.1.0.gemspec
Usando faraday-httpclient 1.0.1
0:  faraday-httpclient (1.0.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-httpclient-1.0.1.gemspec
Usando multipart-post 2.1.1
0:  multipart-post (2.1.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multipart-post-2.1.1.gemspec
Usando faraday-multipart 1.0.3
0:  faraday-multipart (1.0.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-multipart-1.0.3.gemspec
Usando faraday-net_http 1.0.1
0:  faraday-net_http (1.0.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http-1.0.1.gemspec
Usando faraday-net_http_persistent 1.2.0
0:  faraday-net_http_persistent (1.2.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http_persistent-1.2.0.gemspec
Usando faraday-patron 1.0.0
0:  faraday-patron (1.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-patron-1.0.0.gemspec
Usando faraday-rack 1.0.0
0:  faraday-rack (1.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-rack-1.0.0.gemspec
Usando faraday-retry 1.0.3
0:  faraday-retry (1.0.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-retry-1.0.3.gemspec
Usando ruby2_keywords 0.0.5
0:  ruby2_keywords (0.0.5) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby2_keywords-0.0.5.gemspec
Usando faraday 1.9.3
0:  faraday (1.9.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-1.9.3.gemspec
Usando fast_blank 1.0.1
0:  fast_blank (1.0.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_blank-1.0.1.gemspec
Usando fast_xs 0.8.0
0:  fast_xs (0.8.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_xs-0.8.0.gemspec
Usando fastimage 2.2.6
0:  fastimage (2.2.6) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fastimage-2.2.6.gemspec
Usando ffi 1.15.5
0:  ffi (1.15.5) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ffi-1.15.5.gemspec
Usando fspath 3.1.2
0:  fspath (3.1.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fspath-3.1.2.gemspec
Usando gc_tracer 1.5.1
0:  gc_tracer (1.5.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/gc_tracer-1.5.1.gemspec
Usando guess_html_encoding 0.0.11
0:  guess_html_encoding (0.0.11) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/guess_html_encoding-0.0.11.gemspec
Usando hana 1.3.7
0:  hana (1.3.7) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hana-1.3.7.gemspec
Usando hashie 5.0.0
0:  hashie (5.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hashie-5.0.0.gemspec
Usando highline 2.0.3
0:  highline (2.0.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/highline-2.0.3.gemspec
Usando hkdf 0.3.0
0:  hkdf (0.3.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hkdf-0.3.0.gemspec
Usando htmlentities 4.3.4
0:  htmlentities (4.3.4) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/htmlentities-4.3.4.gemspec
Usando http_accept_language 2.1.1
0:  http_accept_language (2.1.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/http_accept_language-2.1.1.gemspec
Usando image_size 3.0.1
0:  image_size (3.0.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_size-3.0.1.gemspec
Usando in_threads 1.5.4
0:  in_threads (1.5.4) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/in_threads-1.5.4.gemspec
Usando progress 3.6.0
0:  progress (3.6.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/progress-3.6.0.gemspec
Usando image_optim 0.31.1
0:  image_optim (0.31.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_optim-0.31.1.gemspec
Usando json 2.6.1
0:  json (2.6.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json-2.6.1.gemspec
Usando uri_template 0.7.0
0:  uri_template (0.7.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uri_template-0.7.0.gemspec
Usando json_schemer 0.2.18
0:  json_schemer (0.2.18) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json_schemer-0.2.18.gemspec
Usando jwt 2.3.0
0:  jwt (2.3.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jwt-2.3.0.gemspec
Usando kgio 2.11.4
0:  kgio (2.11.4) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/kgio-2.11.4.gemspec
Usando libv8-node 16.10.0.0 (x86_64-linux)
0:  libv8-node (16.10.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/libv8-node-16.10.0.0-x86_64-linux.gemspec
Usando request_store 1.5.0
0:  request_store (1.5.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/request_store-1.5.0.gemspec
Usando lograge 0.11.2
0:  lograge (0.11.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lograge-0.11.2.gemspec
Usando logstash-event 1.2.02
0:  logstash-event (1.2.02) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-event-1.2.02.gemspec
Usando logstash-logger 0.26.1
0:  logstash-logger (0.26.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-logger-0.26.1.gemspec
Usando logster 2.10.1
0:  logster (2.10.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logster-2.10.1.gemspec
Usando lru_redux 1.1.0
0:  lru_redux (1.1.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lru_redux-1.1.0.gemspec
Usando lz4-ruby 0.3.3
0:  lz4-ruby (0.3.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lz4-ruby-0.3.3.gemspec
Usando maxminddb 0.1.22
0:  maxminddb (0.1.22) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/maxminddb-0.1.22.gemspec
Usando memory_profiler 1.0.0
0:  memory_profiler (1.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/memory_profiler-1.0.0.gemspec
Usando message_bus 4.0.0
0:  message_bus (4.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/message_bus-4.0.0.gemspec
Usando mini_racer 0.6.1
0:  mini_racer (0.6.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_racer-0.6.1.gemspec
Usando redis 4.5.1
0:  redis (4.5.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-4.5.1.gemspec
Usando sidekiq 6.3.1
0:  sidekiq (6.3.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sidekiq-6.3.1.gemspec
Usando mini_scheduler 0.13.0
0:  mini_scheduler (0.13.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_scheduler-0.13.0.gemspec
Usando mini_sql 1.1.3
0:  mini_sql (1.1.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_sql-1.1.3.gemspec
Usando mini_suffix 0.3.3
0:  mini_suffix (0.3.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_suffix-0.3.3.gemspec
Usando multi_json 1.15.0
0:  multi_json (1.15.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_json-1.15.0.gemspec
Usando multi_xml 0.6.0
0:  multi_xml (0.6.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_xml-0.6.0.gemspec
Usando mustache 1.1.1
0:  mustache (1.1.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mustache-1.1.1.gemspec
Usando nio4r 2.5.8
0:  nio4r (2.5.8) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nio4r-2.5.8.gemspec
Usando oauth 0.5.8
0:  oauth (0.5.8) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth-0.5.8.gemspec
Usando oauth2 1.4.7
0:  oauth2 (1.4.7) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth2-1.4.7.gemspec
Usando oj 3.13.2
0:  oj (3.13.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oj-3.13.2.gemspec
Usando omniauth 1.9.1
0:  omniauth (1.9.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-1.9.1.gemspec
Usando omniauth-oauth2 1.7.2
0:  omniauth-oauth2 (1.7.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth2-1.7.2.gemspec
Usando omniauth-facebook 9.0.0
0:  omniauth-facebook (9.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-facebook-9.0.0.gemspec
Usando omniauth-github 1.4.0
0:  omniauth-github (1.4.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-github-1.4.0.gemspec
Usando omniauth-google-oauth2 0.8.2
0:  omniauth-google-oauth2 (0.8.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-google-oauth2-0.8.2.gemspec
Usando omniauth-oauth 1.2.0
0:  omniauth-oauth (1.2.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth-1.2.0.gemspec
Usando omniauth-twitter 1.4.0
0:  omniauth-twitter (1.4.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-twitter-1.4.0.gemspec
Usando optimist 3.0.1
0:  optimist (3.0.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/optimist-3.0.1.gemspec
Usando pg 1.2.3
0:  pg (1.2.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pg-1.2.3.gemspec
Usando pry 0.13.1
0:  pry (0.13.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-0.13.1.gemspec
Usando pry-byebug 3.9.0
0:  pry-byebug (3.9.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-byebug-3.9.0.gemspec
Usando pry-rails 0.3.9
0:  pry-rails (0.3.9) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-rails-0.3.9.gemspec
Usando puma 5.5.2
0:  puma (5.5.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/puma-5.5.2.gemspec
Usando r2 0.2.7
0:  r2 (0.2.7) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/r2-0.2.7.gemspec
Usando rack-mini-profiler 2.3.3
0:  rack-mini-profiler (2.3.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-mini-profiler-2.3.3.gemspec
Usando rack-protection 2.1.0
0:  rack-protection (2.1.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-protection-2.1.0.gemspec
Usando rails_failover 0.7.3
0:  rails_failover (0.7.3) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_failover-0.7.3.gemspec
Usando rails_multisite 4.0.0
0:  rails_multisite (4.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_multisite-4.0.0.gemspec
Usando raindrops 0.20.0
0:  raindrops (0.20.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/raindrops-0.20.0.gemspec
Usando rbtrace 0.4.14
0:  rbtrace (0.4.14) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rbtrace-0.4.14.gemspec
Usando rchardet 1.8.0
0:  rchardet (1.8.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rchardet-1.8.0.gemspec
Usando redis-namespace 1.8.1
0:  redis-namespace (1.8.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-namespace-1.8.1.gemspec
Usando rexml 3.2.5
0:  rexml (3.2.5) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rexml-3.2.5.gemspec
Usando rinku 2.0.6
0:  rinku (2.0.6) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rinku-2.0.6.gemspec
Usando rotp 6.2.0
0:  rotp (6.2.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rotp-6.2.0.gemspec
Usando rqrcode_core 1.2.0
0:  rqrcode_core (1.2.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode_core-1.2.0.gemspec
Usando rqrcode 2.1.0
0:  rqrcode (2.1.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode-2.1.0.gemspec
Usando rss 0.2.9
0:  rss (0.2.9) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rss-0.2.9.gemspec
Usando rtlit 0.0.5
0:  rtlit (0.0.5) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rtlit-0.0.5.gemspec
Usando ruby-readability 0.7.0
0:  ruby-readability (0.7.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby-readability-0.7.0.gemspec
Usando rubyzip 2.3.2
0:  rubyzip (2.3.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rubyzip-2.3.2.gemspec
Usando sanitize 6.0.0
0:  sanitize (6.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sanitize-6.0.0.gemspec
Usando sassc 2.0.1
0:  sassc (2.0.1) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-2.0.1.gemspec
Usando sprockets-rails 3.4.2
0:  sprockets-rails (3.4.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-rails-3.4.2.gemspec
Usando tilt 2.0.10
0:  tilt (2.0.10) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tilt-2.0.10.gemspec
Usando sassc-rails 2.1.2
0:  sassc-rails (2.1.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-rails-2.1.2.gemspec
Usando seed-fu 2.3.9
0:  seed-fu (2.3.9) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/seed-fu-2.3.9.gemspec
Usando sshkey 2.0.0
0:  sshkey (2.0.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sshkey-2.0.0.gemspec
Usando stackprof 0.2.17
0:  stackprof (0.2.17) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/stackprof-0.2.17.gemspec
Usando uglifier 4.2.0
0:  uglifier (4.2.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uglifier-4.2.0.gemspec
Usando unf_ext 0.0.8
0:  unf_ext (0.0.8) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf_ext-0.0.8.gemspec
Usando unf 0.1.4
0:  unf (0.1.4) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf-0.1.4.gemspec
Usando unicorn 6.1.0
0:  unicorn (6.1.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unicorn-6.1.0.gemspec
Usando webpush 1.1.0
0:  webpush (1.1.0) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/webpush-1.1.0.gemspec
Usando xorcist 1.1.2
0:  xorcist (1.1.2) de /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/xorcist-1.1.2.gemspec
Bundle completo! 127 dependências do Gemfile, 176 gems instaladas.
Gems nos grupos 'test' e 'development' não foram instaladas.
Gems empacotadas estão instaladas em `./vendor/bundle`
I, [2022-02-07T16:59:07.345929 #1]  INFO -- : > cd /var/www/discourse && [ ! -d 'node_modules' ] || su discourse -c 'yarn install --production && yarn cache clean'
warning O campo de resolução "lodash@4.17.21" é incompatível com a versão solicitada "lodash@4.17.15"
warning " > @mixer/parallel-prettier@2.0.1" tem dependência peer não atendida "prettier@^2.0.0".
I, [2022-02-07T16:59:07.345929 #1]  INFO -- : yarn install v1.22.17
[1/5] Validando package.json...
[2/5] Resolvendo pacotes...
[3/5] Buscando pacotes...
[4/5] Vinculando dependências...
[5/5] Compilando pacotes frescos...
$ yarn --cwd app/assets/javascripts/discourse
[1/4] Resolvendo pacotes...
[2/4] Buscando pacotes...
[3/4] Vinculando dependências...
[4/4] Compilando pacotes frescos...
sucesso Arquivo de bloqueio salvo.
Concluído em 62.60s.
Concluído em 109.81s.
yarn cache v1.22.17
sucesso Cache limpo.
Concluído em 9.95s.
I, [2022-02-07T16:59:07.348323 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2022-02-07T16:59:12.054248 #1]  INFO -- : docker_manager já está na versão compatível mais recente
discourse-chinese-localization-pack já está na versão compatível mais recente
onebox já está na versão compatível mais recente
discourse-github já está na versão compatível mais recente
discourse-solved já está na versão compatível mais recente
discourse-signatures já está na versão compatível mais recente
discourse-sitemap já está na versão compatível mais recente
discourse-translator já está na versão compatível mais recente
discourse-adplugin já está na versão compatível mais recente
I, [2022-02-07T16:59:12.054938 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake abortado!
Discourse::Deprecation: Aviso de depreciação: O evento :site_setting_saved está obsoleto. Por favor, use :site_setting_changed em vez disso (obsoleto desde Discourse 2.3.0beta8) (remoção em Discourse 2.4)
Em /var/www/discourse/plugins/discourse-chinese-localization-pack/plugin.rb:65:in `block in activate!`
lib/discourse.rb:860:in `deprecate'
/var/www/discourse/lib/discourse_event.rb:20:in `on'
/var/www/discourse/plugins/discourse-chinese-localization-pack/plugin.rb:65:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:478:in `block in notify_after_initialize'
/var/www/discourse/lib/plugin/instance.rb:476:in `each'
/var/www/discourse/lib/plugin/instance.rb:476:in `notify_after_initialize'
/var/www/discourse/config/application.rb:362:in `each'
/var/www/discourse/config/application.rb:362:in `block (2 levels) in <class:Application>'
/var/www/discourse/lib/plugin_initialization_guard.rb:5:in `plugin_initialization_guard'
/var/www/discourse/config/application.rb:361:in `block in <class:Application>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/lazy_load_hooks.rb:68:in `block in execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/lazy_load_hooks.rb:61:in `with_execution_control'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/lazy_load_hooks.rb:66:in `execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/lazy_load_hooks.rb:52:in `block in run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/lazy_load_hooks.rb:51:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/lazy_load_hooks.rb:51:in `run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application/finisher.rb:140:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application.rb:391:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/railtie.rb:207:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/railtie.rb:207:in `method_missing'
/var/www/discourse/config/environment.rb:7:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/loaded_features_index.rb:88:in `register'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/zeitwerk-2.5.3/lib/zeitwerk/kernel.rb:35:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:332:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:299:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:332:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application.rb:367:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application.rb:533:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
Tarefas: TOP => db:migrate => db:load_config => environment
(Veja o rastreamento completo executando a tarefa com --trace)
I, [2022-02-07T16:59:43.018316 #1]  INFO -- : gem install omniauth-douban-oauth2 -v 0.0.7 -i /var/www/discourse/plugins/discourse-chinese-localization-pack/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Instalado com sucesso omniauth-douban-oauth2-0.0.7
1 gem instalado
gem install omniauth-qq -v 0.3.0 -i /var/www/discourse/plugins/discourse-chinese-localization-pack/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Instalado com sucesso omniauth-qq-0.3.0
1 gem instalado
gem install omniauth-weibo-oauth2 -v 0.5.2 -i /var/www/discourse/plugins/discourse-chinese-localization-pack/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Instalado com sucesso omniauth-weibo-oauth2-0.5.2
1 gem instalado
gem install sawyer -v 0.8.2 -i /var/www/discourse/plugins/discourse-github/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Instalado com sucesso sawyer-0.8.2
1 gem instalado
gem install octokit -v 4.21.0 -i /var/www/discourse/plugins/discourse-github/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Instalado com sucesso octokit-4.21.0
1 gem instalado
gem install aws-sdk-translate -v 1.35.0 -i /var/www/discourse/plugins/discourse-translator/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Instalado com sucesso aws-sdk-translate-1.35.0
1 gem instalado
I, [2022-02-07T16:59:43.020601 #1]  INFO -- : Terminando processos assíncronos
I, [2022-02-07T16:59:43.020813 #1]  INFO -- : Enviando INT para HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 41
I, [2022-02-07T16:59:43.021060 #1]  INFO -- : Enviando TERM para exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 102
2022-02-07 16:59:43.021 UTC [41] LOG:  recebido pedido de desligamento rápido
102:signal-handler (1644253183) Recebido SIGTERM agendando desligamento...
2022-02-07 16:59:43.023 UTC [41] LOG:  abortando transações ativas
2022-02-07 16:59:43.031 UTC [41] LOG:  trabalhador em segundo plano "logical replication launcher" (PID 50) saiu com código de saída 1
2022-02-07 16:59:43.033 UTC [45] LOG:  desligando
2022-02-07 16:59:43.073 UTC [41] LOG:  sistema de banco de dados desligado
102:M 07 Fev 2022 16:59:43.090 # Desligamento solicitado pelo usuário...
102:M 07 Fev 2022 16:59:43.090 * Salvando o snapshot RDB final antes de sair.
102:M 07 Fev 2022 16:59:43.131 * Banco de dados salvo em disco
102:M 07 Fev 2022 16:59:43.131 # Redis está pronto para sair, tchau...
FALHA
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' falhou com retorno #<Process::Status: pid 531 exit 1>
Localização da falha: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec falhou com os parâmetros {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
4591d3da57ec7a81ec575bdcaec036d727350b6618f0afbe01f5ddacacfab9d9
** FALHA NA INICIALIZAÇÃO ** por favor, role para cima e procure por mensagens de erro anteriores, pode haver mais de uma.
./discourse-doctor pode ajudar a diagnosticar o problema.
==================== FIM DO LOG DE RECONSTRUÇÃO ====================
Falha ao reconstruir o aplicativo.
Verificando o nome do seu domínio . . .
Conexão com forum.magentochina.org bem-sucedida.
Provavelmente você deve remover qualquer plugin não oficial e reconstruir.
Tentando reiniciar o container existente. . .
Arquitetura x86_64 detectada.
iniciando container existente
+ /usr/bin/docker start app
app
Container reiniciado.
==================== PLUGINS ====================
          - git clone https://github.com/erickguan/discourse-chinese-localization-pack.git
          - git clone https://github.com/discourse/onebox.git
          - git clone https://github.com/discourse/discourse-github.git
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/discourse/discourse-signatures.git
          - git clone https://github.com/discourse/discourse-sitemap.git
          - git clone https://github.com/discourse/discourse-translator.git
#          - git clone https://github.com/discourse/discourse-subscriptions.git
          - git clone https://github.com/discourse/discourse-adplugin.git
AVISO:
Você tem o que parecem ser plugins não oficiais.
Se estiver tendo problemas, você deve desativá-los e tentar reconstruir novamente.
Veja https://github.com/discourse/discourse/blob/main/lib/plugin/metadata.rb para a lista oficial.
Versão do Discourse em forum.magentochina.org: Discourse 2.7.12
Versão do Discourse no localhost: NÃO ENCONTRADO
==================== PROBLEMA DE DNS ====================
Este servidor relata NÃO ENCONTRADO, mas forum.magentochina.org relata Discourse 2.7.12 .
Isso sugere que você tem um problema de DNS ou que um proxy intermediário é o culpado.
Se você estiver usando Cloudflare, ou uma CDN, ela pode estar configurada incorretamente.
==================== INFORMAÇÕES DE MEMÓRIA ====================
SO: Linux
RAM (MB): 16753
              total        usado        livre      compartilhado  buff/cache   disponível
Mem:          15977        2381        1732         256       11863       13012
Swap:           951          15         936
==================== VERIFICAÇÃO DE ESPAÇO EM DISCO ====================
---------- Espaço em Disco do SO ----------
Sistema de Arquivo           Tamanho  Usado Disp. Uso% Montado em
/dev/mapper/vg-root   38G   17G   21G  45% /
==================== INFORMAÇÕES DE DISCO ====================
Disco /dev/sdb: 160 GiB, 171798691840 bytes, 335544320 setores
Modelo do disco: QEMU HARDDISK
Unidades: setores de 1 * 512 = 512 bytes
Tamanho do setor (lógico/físico): 512 bytes / 512 bytes
Tamanho de E/S (mínimo/ótimo): 512 bytes / 512 bytes
Disco /dev/sda: 40 GiB, 42949672960 bytes, 83886080 setores
Tipo de rótulo de disco: dos
Identificador do disco: 0xd29dd11e
Dispositivo     Boot Início      Fim  Setores Tamanho Id Tipo
/dev/sda1  *     2048 83884031 83881984  40G 8e Linux LVM
Disco /dev/mapper/vg-root: 37.2 GiB, 39950745600 bytes, 78028800 setores
Disco /dev/mapper/vg-boot: 1.9 GiB, 1996488704 bytes, 3899392 setores
Disco /dev/mapper/vg-swap: 952 MiB, 998244352 bytes, 1949696 setores
==================== FIM DAS INFORMAÇÕES DE DISCO ====================
==================== TESTE DE E-MAIL ====================
Para um teste robusto, obtenha um endereço em http://www.mail-tester.com/
Enviando e-mail para REDATADO  . .
Testando envio para 58573655@qq.com usando smtp.office365.com:587, nome de usuário:service@magentochina.org com autenticação de login.
======================================== ERRO ========================================
                                    ERRO INESPERADO
504 5.7.4 Tipo de autenticação não reconhecido [HK2PR02CA0191.apcprd02.prod.outlook.com]
====================================== SOLUÇÃO =======================================
Este não é um erro comum. Nenhuma solução recomendada existe!
Por favor, reporte a mensagem de erro exata acima para https://meta.discourse.org/
(E uma solução, se você encontrar uma!)
==================== CONCLUÍDO! ====================
A saída deste programa pode estar disponível em http://forum.magentochina.org/NTgwYTViMWQwY2ZjMDRj.txt
Você deve inspecionar esse arquivo cuidadosamente antes de compartilhar o URL.
Você pode examinar a saída deste script com
LESS=-Ri less /tmp/discourse-debug.txt
MAS PRIMEIRO, certifique-se de que conhece os três primeiros comandos abaixo!!!
Comandos para saber ao visualizar o arquivo com o comando acima (chamado 'less'):
q              -- sair
/error<ENTER>  -- pesquisar pela palavra 'error'
n              -- pesquisar pela próxima ocorrência
g              -- ir para o início do arquivo
f              -- avançar uma página
b              -- voltar uma página
G              -- ir para o final do arquivo
Este plugin está quebrado. Tente removê-lo do app.yml e reconstruir.
Obrigado.
Quando removermos este plus, será corrigido:
