Help to merge forum from Kunena
I have been traveling the long forum road. For more then 15 years I have been running a community for medical students in Denmark @ studmed.dk
For the first years I have been using phpBB2. Then in I did migrate to Joomla using Kunena on top of it. I have runned the site as a non-commerciel, none advertising site.
And now my site have been hacked and is down :sleepy: Therefore I would like to give Discourse a try!
But damn there is a steep learning curve using discourse!
I did setup a Ubuntu server using vultr and was able to install Discourse. And then there is the migration issue.
Seems like I need a ph.D in serverhosting and programming… Im not able to do the import script thing :frowning:
What will it cost to get someone to do it for me?
I have the .sql file and the attachment folder…
「いいね!」 1
There are import scripts for kunena and Kunena3. I apparently did some work on the Kunena 3 script and you can read about that here: Importing from Kunena 3.
「いいね!」 4
Yep I know.
But Im not able to run it as I dont know howto run discourse and a mysql server at the same setup…
I do several imports a month. I sent you a personal message. You can also post specifics of your project (number of posts and users, timeine) with a budget in the marketplace.
Let me know if you’d like my help.
Thanks
But I dont have that much money for this issue.
The site was driven in my spare time as a non-commerciel forum.
It have 10.000 users (many old “dead” users) 5000 posts and 40.000 replies.
I try to see if Im able to add mysql2 to my discourse setup and run the import script.
What do you think it will cost if I give you my sql database backup file.
And you import it and make a backup file I could use on my vanilla board and import it there?
移行がどのように行われたかはわかりませんが、Discourse サイトは正常に稼働しています。
「いいね!」 3
