Migrate from another forum to Discourse
:mega: This guide serves as a high level overview of the migration process.
For specifics on the wide range of forum softwares to import, including Vanilla, phpBB3, SMF2, bbPress, and vBulletin, review our dedicated tutorials.
Not all scripts have tutorials, but an exhaustive list of available imports is available under the script/import_scripts folder on GitHub. For larger migrations, there is also a faster script/bulk_import system that writes directly to the database.
So you want to migrate your existing forum to Discourse? That’s great! Let’s get started!
1. Set Up a Development Environment
See the following topic to set up your environment: Set up an environment to migrate another forum to Discourse
(If you are developing a new importer or planning to make significant changes to an existing importer, you may wish instead to set up a development environment. Refer to the macOS, Ubuntu, or Windows installation guide for development.)
2. Read the Script & Modify as Needed
We highly recommend to read the script before performing import. You may also need to modify the script file before beginning.
Near the top of the scripts, a connection is made to the database containing the source data. At a minimum, these connection settings will need to be changed.
You may also want to change the SQL queries that fetch the data to import into Discourse. For example, if you want to exclude really old posts, you can add a condition to the WHERE clauses.
3. Run the Import
To run the intended import script, run the following commands:
cd path/to/your/discourse_folder
bundle exec ruby script/import_scripts/=import_script=.rb
This process will be similar for other import scripts.
Once the import is complete, verify the data is imported correctly.
4. Take a Backup & Restore It
If you’ve followed this guide and are running a development instance, you’ll need to take a backup of the database and restore it to the production Discourse instance.
Backup and restore via UI:
Restore via CLI:
Last Reviewed by @sam on 2026-03-16T13:00:00Z
2 posts were split to a new topic: Does Discourse cost money?
