Aide pour les images d'arrière-plan des catégories
what size background image works best? I have tried over 100 images and gifs, and they all get stretched, and blurry. usually 1/2 the image isn’t even viewable
You’re going to want something fairly large in dimension and in a landscape orientation (but watch out for file size too, you don’t want to force everyone to download a huge image).
For example, I accidentally took this photo of my couch. The dimensions are 1920 x 1440 and it fits my screen as a background image (text is unreadable over it, but that’s a separate issue).
Note that the image is set to background-size: cover; by default — so this means that the image will be scaled-up to fill the entire browser window without repeating the image (and likely cropped somewhat unless my window is in the same 4:3 ratio as the image). Small images will be sized up proportionately until they fit the entire window. You can change this behavior using CSS for the category, for example:
body.category-example {
  background-size: 25%:
Now your background image is much smaller, and tiled to fill the screen.
You’ll want to work with background-size, background-repeat, and background-position in your site’s CSS to find out which properties will work for your specific image.
9 « J'aime »
Can we add this tip to the UI for the feature, somewhere?
1 « J'aime »
i dont see anywhere under the category where CSS is.
or am i looking in the wrong places?
All of your CSS is controlled under admin > customize > themes, by “CSS for the category” I meant that you can target a specific category because we add CSS classes to the page when relevant.
So in the case of a category named “Other” we add the .category-other class to the page’s body tag, so you can use something like this in your general customizations to target that specific category.
body.category-other {
  // your CSS for the category here
8 « J'aime »
Quelle est la taille recommandée pour l’arrière-plan d’une catégorie, par exemple la largeur ?
Je cherche également des recommandations de taille pour une image de catégorie.
1 « J'aime »
Cela varie beaucoup en fonction de l’effet que vous souhaitez obtenir…
Pour les images d’arrière-plan… probablement aussi large que possible tout en gardant la taille du fichier raisonnable (disons peut-être moins de 150 ko ? Un service comme https://tinypng.com/ peut aider à réduire la taille du fichier). Probablement dans la plage de 1440 px à 1920 px de large…
Pour les logos ou images de catégories, j’aime personnellement les carrés, d’environ 150 px… mais si vous personnalisez la mise en page autrement, presque n’importe quelle taille ou orientation peut bien fonctionner.
2 « J'aime »
Comme ce site présente certaines limitations, j’utilise parfois https://pngquant.org/. Il propose un exécutable et réalise le même travail sans ces limitations ; je pense qu’il utilise la même méthode de compression.
4 « J'aime »
