I am trying to fix the s3/cdn settings on my site and running into problems. A little back history: I had been using digital ocean spaces with bunny.net for the cdn, I had everything set up properly in the site settings, but I had never set up DISCOURSE_CDN_URL in the app.yml because I didn’t understand how it worked or it’s importance. Recently I switched over to Amazon S3 after I started having issues with DO Spaces, but stuck with bunny.net for the cdn. I think I have that part of the changeover figured out and @pfaffman is going to help me remap the database.
The issue I’m having now is with setting the DISCOURSE_CDN_URL. What I have done is create a new pull zone on bunny for this, set the origin URL to https://community.naturephotographers.network which is my forum. I have a CNAME for this pointing to assets.naturephotographers.network. I then set DISCOURSE_CDN_URL to https://assets.naturephotographers.network and it rebuilds okay, but the assets from the site are not being pulled from the cdn of assets.naturephotographers.network, they are coming from the amazon bucket for some reason.
I tried running this rake task
after_assets_precompile:
- exec:
cd: $home
cmd:
- sudo -E -u discourse bundle exec rake s3:upload_assets
But it fails with this error:
I, [2021-07-26T13:31:31.754617 #1] INFO -- : > cd /var/www/discourse && sudo -E -u discourse bundle exec rake s3:upload_assets
`/root` is not writable.
Bundler will use `/tmp/bundler20210726-6572-1a099eq6572' as your home directory temporarily.
ERROR: Ensure S3 is configured in config/discourse.conf or environment vars
I, [2021-07-26T13:31:42.586559 #1] INFO -- :
I, [2021-07-26T13:31:42.587455 #1] INFO -- : Terminating async processes
I, [2021-07-26T13:31:42.587523 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 56
I, [2021-07-26T13:31:42.587764 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 173
173:signal-handler (2021-07-26 13:31:42.588 UTC [56] LOG: received fast shutdown request
1627306302) Received SIGTERM scheduling shutdown...
2021-07-26 13:31:42.594 UTC [56] LOG: aborting any active transactions
2021-07-26 13:31:42.596 UTC [56] LOG: background worker "logical replication launcher" (PID 65) exited with exit code 1
2021-07-26 13:31:42.599 UTC [6573] FATAL: terminating autovacuum process due to administrator command
2021-07-26 13:31:42.599 UTC [6573] CONTEXT: while vacuuming block 74749 of relation "pg_toast.pg_toast_21988"
2021-07-26 13:31:42.603 UTC [60] LOG: shutting down
173:M 26 Jul 2021 13:31:42.630 # User requested shutdown...
173:M 26 Jul 2021 13:31:42.630 * Saving the final RDB snapshot before exiting.
2021-07-26 13:31:42.766 UTC [56] LOG: database system is shut down
173:M 26 Jul 2021 13:31:43.123 * DB saved on disk
173:M 26 Jul 2021 13:31:43.123 # Redis is now ready to exit, bye bye...
Here are my site settings for s3/cdn:
Another interesting side note; if I have all of my s3/cdn settings in my app.yml rather than site settings it breaks my site and I have only a white page despite the settings being exactly the same, with a ton of 403 errors in the console:
## S3 Configuration
DISCOURSE_USE_S3: true
DISCOURSE_S3_REGION: us-west-1
DISCOURSE_S3_ACCESS_KEY_ID: ***
DISCOURSE_S3_SECRET_ACCESS_KEY: ***
DISCOURSE_S3_CDN_URL: https://images.naturephotographers.network
DISCOURSE_S3_BUCKET: npnimages
DISCOURSE_S3_BACKUP_BUCKET: npn-backup
DISCOURSE_BACKUP_LOCATION: s3
Any ideas? Thank you!
