Help with locking down forum
Isla seeks urgent help to lock down their forum, making it inaccessible to viewers. merefield suggests enabling ‘login required’ in site settings to hide the forum from anonymous users, but warns this may negatively impact SEO. They also advise adjusting group read rights in Category Security settings to hide specific categories. pfaffman proposes logging out all users and putting the site in read-only mode, or stopping the app. Lilly provides the command to log out all users and suggests posting a banner or global notice to inform users. They also share a link to a relevant topic on handling compromised forums. pfaffman appreciates Lilly’s input on how to log out users.
I need to lock down my space as a matter of urgency, so that nobody can view anything. How do I do this? Is this possible?
You may have to go into more detail I suspect to describe exactly what you need.
To hide the forum from anonymous users check login required in site settings. However, note this will ruin SEO as search engines will have nothing to link to.
Beyond that start removing groups from read rights in Category Security settings which will individually hide Categories.
I’ll come back to this asap, thank you!
You can log out all users and put the site in read only mode.
But you can also just do a
  ./launcher stop app
Probably worth adding how you can do that?
i believe it’s
./launcher enter app
rails r 'UserAuthToken.destroy_all'
You may want to consider posting a banner or global notice before running the command to inform your users.
also this topic may help, depending on what your concerns are
Well, yeah, if I knew how! :rofl: Thanks, @Lilly!
