Hello,
I searched in the settings but I cannot find a way to temporarily disable a forum (such as to disable it for upgrades/changes/etc.). Where would I find such an option?
I want to disable logins that are not administrators and have it show as offline should anyone attempt to sign in.
Thanks
In the backup area, press the “enable read only mode” button.
In that section I only see:
Enable read only mode while taking a backup
There doesn’t seem to be a more ‘permanent’ version. Also if read only would be the only way, can I disable logins as well?
Got it thank you! Was looking in the Backup Settings instead.
Also, in the event I wish to disable log ins or take the forum completely offline is this possible?
Stephen
(Stephen)
July 20, 2019, 1:41am
6
If you don’t want anyone to access it change your a record and add it to your hosts.
DiscoWebmaster:
disable log ins
You can disable logins via your site settings, or re-rerun the setup wizard which will also allow you to make your site login required.
frold
October 25, 2019, 11:07am
8
If you want to disable it totally.
Eg with a msg like “The forum is temporary down due to maintenance”
As I need to move from server 1 (vultr) to server 2 (digitalocean)
and in that case also from url.tld to forum.url.tld
how do I do that?
pfaffman
(Jay Pfaffman)
October 25, 2019, 11:18am
9
I usually just put the old site in read only mode while making the transition to the new site.
Stephen:
This isn’t working, perhaps due to caching? I’m using AWS and DigitalOcean. Users who are logged in can still browse the old Discourse instance. Can I force a logout of everyone?
Stephen
(Stephen)
October 13, 2020, 1:46am
12
Why not stop the container
Stephen:
stop the container
If I ssh into the droplet, cd into /var/discourse/, and run ./launcher stop app, it outputs:
+ /usr/bin/docker stop -t 10 app
app
But I’m still able to navigate and interact with the old Discourse instance in my other open web browser.
Stephen
(Stephen)
October 13, 2020, 3:02am
14
Are you sure you connected to the correct server?
What’s the result of docker ps?
Yes, I see it named in the command-line prompt.
What’s the result of docker ps ?
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
riking
(Kane York)
October 25, 2020, 7:44am
16
That says that nothing’s running. Are you sure you’re administrating the correct server?
pfaffman
(Jay Pfaffman)
October 25, 2020, 12:20pm
17
Discourse caches a bunch of stuff, so sometimes a site will appear to display when it’s down. If the site still shows it you do a hard reload, you’re not logged in to the right server
I eventually just gave up and removed the subdomain from public service entirely, thank you.
