Help with SSL (Some issues to be fixed)
What would I like to be done?
I need someone to help me to get a grade of A+ on my SSL and fix the error I get via feedvalidator. I guess when the SSL is fixed, this will automatically will be fixed too since it is a SSL problem.
This is my forum URL: http://bit.ly/2j2oom9
This is my SSL score: Feed Validator Results: http://forums.7host.ir/latest.rss
This is the feed error: SSL Server Test (Powered by Qualys SSL Labs)
When do I need it to be done?
By today or tomorrow
I know I cannot buy your knowledge, but what I can afford is $20 bucks.
If convenient, please message me.
Thanks
You’re missing the intermediate CA certificate. The SSL labs report shows what cert you’re missing. Find it (Certum should have sent it to you with the end entity certificate) and paste it in the same file as the end entity certificate, immediately after it in the file. Restart nginx (or the whole container, if you’re feeling brutal) and everything should start working.
Thanks mate, All is set and I am getting A+ score now.
but one thing about my RSS feed.
It is giving me some other errors which I believe it entirely isn’t related to SSL.
Here: Feed Validator Results: https://forums.7host.ir/latest.rss
Any idea?
You’d be better off posting that as a separate topic, with its own, more descriptive, title. I can see what’s going on, I’m just not sure how best to fix it, so it’ll be best if someone with more knowledge in that space chimes in.
Will do. Thanks mate.
