Hidden replies: educational settings
The discussion explores a request from jgmac1106 to implement hidden replies for educational settings, specifically allowing teachers to submit assessment responses that remain invisible to other students. While the feature was initially considered for use with whispers or private messages, jgmac1106 found those methods cumbersome. elijah questioned the distinction between hidden replies and whispers, suggesting teachers could be considered “staff” elijah. pfaffman asked if whispers are indeed limited to staff only and proposed a write-only category as an alternative solution where users could post without viewing others’ content. pfaffman reiterated this question after codinghorror clarified that implementing per-topic permissions would require a massive rearchitecture of Discourse, making it highly unlikely. Ultimately, jgmac1106 acknowledged the constraints and noted that learning is often better in open environments, deciding to encourage clients against hiding responses.
I have been searching the forum about hidden replies and wanted to put out another use case.
I was looking for this feature as well as I use Discourse when building courses for educational institutions. They generally want open replies but occasionally for assessment purposes teachers do not want students to see the replies as others well.
I experimented with whispers and private messaging but this seemed to cumbersome for my learners.
TLDR: Hidden replies would be a neat feature.
إعجاب واحد (1)
How do you see hidden replies working differently than whispers?
إعجاب واحد (1)
Don’t whispers work only for staff?
It would be great to have a write-only category, where people could post to a category, but not see other people’s posts.
3 إعجابات
See in my mind “teacher” == “staff”.
This implies per-topic permissions which would be a massive rearchitecting of Discourse. Highly unlikely to happen.
That makes sense , but how about write-only categories?
Thanks for the heads up Jeff. Learning is better in the open anyways. I try to push clients to not care about people seeing each other’s responses.
