GSeven
19 באוקטובר, 2016, 11:46am
1
Is it possible to hide the ‘create topic’ button on the home page?
i would like my users to navigate to the appropriate category/subcategory before posting a topic, because then the correct category option is automatically placed in the composer, instead of having to scroll through what will be hundreds of categories and subcategories in the drop down menu looking for the right one.
Does anybody know how to do this please?
cpradio
(cpradio)
19 באוקטובר, 2016, 11:56am
Try this CSS Rule
body:not([class*='category-']) #create-topic {
display: none;
It will only let the create-topic button appear on category pages.
GSeven
19 באוקטובר, 2016, 11:59am
3
Yes cpradio, absolutely perfect, top notch support.
many thanks.
GSeven
19 באוקטובר, 2016, 12:10pm
4
actually, can the code be tweeked to show the ‘create topic’ button also in category>subcategory>tag?
cpradio
(cpradio)
19 באוקטובר, 2016, 12:30pm
5
Just to confirm, you have show filter by tag enabled?
GSeven
19 באוקטובר, 2016, 12:33pm
6
i do indeed have it enabled.
so when someone goes to service(category)>county(subcategory)>town(tag) the create topic button is shown.
cpradio
(cpradio)
19 באוקטובר, 2016, 12:34pm
7
K, this is what you will want then
display: none;
body.tags-page #create-topic {
display: block;
GSeven
19 באוקטובר, 2016, 12:39pm
8
Yes, The ‘create topic’ button now shows up on the page when a tag is selected.
absolute genius. i love you guys.
This populates the composer with the correct category and the correct tag.
mstm
(mstm)
7 באפריל, 2021, 10:16am
9
Thanks also from me @cpradio , it would be great as a feature.
Unfortunately it doesn’t work with mobile devices
mstm
(mstm)
7 באפריל, 2021, 4:20pm
10
I have tried everything but I don’t understand how to hide “Create Topic” with mobile devices.
With small displays it is difficult to browse categories and tags, this Contribute > Feature would help a lot, why not add an option to the menu?
manuel
(Manuel Kostka)
7 באפריל, 2021, 5:03pm
11
You can use your browser’s Style Inspector. It shows that the declaration is overwritten by a more specific one on mobile:
So you can either use the more specific declaration for mobile yourself:
body:not([class*="category-"]) .list-controls .container #create-topic {
display: none;
Or give your general declaration priority with the !important property:
body:not([class*="category-"]) #create-topic {
display: none !important;
mstm
(mstm)
7 באפריל, 2021, 5:23pm
12
Thanks @manuel I used the !important property and it works perfectly!
