إخفاء عنوان الموضوع في الرأس
Hi, I have been using the fix in the following thread: Is it possible to disable topic title in header?
<script type="text/discourse-plugin" version="0.8.13">
api.modifyClass('component:discourse-topic', {
    showTopicInHeader() {
        return false;
But as of the new Discourse update v2.3.0.beta9 +469 it does not seem to hide the topic title anymore.
Any help is appreciated, thanks!
Hi @Gershon
Try this, it should work with latest discourse:
        shouldShowTopicInHeader() {
            return false;
</script>
5 إعجابات
Thank you Osama! That fixed it.
إعجاب واحد (1)
