Highlight does not work
I declared the syntax format of the code block as: yaml. But as you can see, it doesn’t work. And the console prints some warning messages.
How can I deal with this problem?
Thanks!
It doesn’t look like yaml is one of the default highlighted languages. I think you need to add it to that admin setting, and then it should work. :crossed_fingers:
