What would you like done?
I would like to implement the following embeds into my website using markdown or some other way: GitHub - itsdouges/armory-embeds: 🛡 Embed Guild Wars 2 widgets on your site! · GitHub
The idea is that the user is supposed to write something short such as {{SKILLNAMEA}} (just an idea) to display a skill image with hover functionality using the embed system that I linked above. So for example if you look at the following page: https://gw2armory.com/kezah/c/Motivational%20Banner If you move your mouse over the any of the skill/item you will actually see some hover info for that skill, the website is using the same embed system. I would like this implemented on my website, if it’s even possible?
When do you need it done?
ASAP.
What is your budget, in $ USD that you can offer for this task?
$500 but flexible based on the quality of the work…
