Hello
Installed Droplet in 5$ Droplet of Digital Ocean
Link is here - forum.bustudymate.in
Everytime it gives Error 502 Bad Gateway
in admin/upgrade it showing error
now emails arent sending
showing another warning
Some problems have been found with your installation of Discourse:
Sidekiq is not running. Many tasks, like sending emails, are executed asynchronously by sidekiq. Please ensure at least one sidekiq process is running. Learn about Sidekiq here.
i’m Newbie in VPS field.. know about Shared hosting only.
is 5$ Droplet is enough to run Discourse smoothly???
when i run rebuild app it gives error
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile' failed with return #<Process::Status: pid 602 exit 137>
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
c7af0edf4fedeb35ee2e198998af6707bbf9abc3208643c7af86f899435058d8
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
FAILED
1cbe4230e6ed1caf1584780b74176fce44b1e42a1ead658fdb66f2058cb26c87
==================== END REBUILD LOG ====================
app still not running!
Checking your domain name . . .
Connection to forum.bustudymate.in succeeded.
You should probably remove any non-standard plugins and rebuild.
==================== PLUGINS ====================
- git clone https://github. com/discourse/docker_manager.git
No non-official plugins detected.
See https:// github. com/discourse/discourse/blob/master/lib/plugin/metadata.rb for the official list.
Discourse version at forum. bustudymate.in: NOT FOUND
Discourse version at localhost: NOT FOUND
==================== MEMORY INFORMATION ====================
RAM (MB): 1009
total used free shared buff/cache available
Mem: 985 158 616 0 210 687
Swap: 0 0 0
==================== DISK SPACE CHECK ====================
---------- OS Disk Space ----------
Filesystem Size Used Avail Use% Mounted on
/dev/vda1 25G 4.5G 20G 19% /
==================== DISK INFORMATION ====================
Disk /dev/vda: 25 GiB, 26843545600 bytes, 52428800 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: C1F9A1FE-534C-4DAC-9299-5CC180C29DCE
Device Start End Sectors Size Type
/dev/vda1 227328 52428766 52201439 24.9G Linux filesystem
/dev/vda14 2048 10239 8192 4M BIOS boot
/dev/vda15 10240 227327 217088 106M Microsoft basic data
Partition table entries are not in disk order.
==================== END DISK INFORMATION ====================
==================== MAIL TEST ====================
For a robust test, get an address from http:// www. mail-tester. com/
Or just send a test message to yourself.
Email address for mail test? ('n' to skip) [me@example.com]: test-90bnp @mail-tester.com
Sending mail to test-90bnp @mail-tester.com. . .
Error response from daemon: Container ef942d318fb4808ed54a9837310145b9f172df666be55d294fab8b7d69161646 is not running
Replacing: SMTP_PASSWORD
Replacing: LETSENCRYPT_ACCOUNT_EMAIL
Replacing: DEVELOPER_EMAILS
Replacing: DISCOURSE_DB_PASSWORD
Replacing: Sending mail to
==================== DONE! ====================
You can examine the output of this script with
LESS=-Ri less /tmp/discourse-debug.txt
BUT FIRST, make sure that you know the first three commands below!!!
Commands to know when viewing the file with the above command (called 'less'):
q -- quit
/error<ENTER> -- search for the word 'error'
n -- search for the next occurrence
g -- go to the beginning of the file
f -- go forward a page
b -- go back a page
G -- go to the end of the file
It done
successull
Now no error messages in dashboard
emails are not getting for registerd users
configured correctly.. in test mail it shows successfull
but in gmail no one get email
