איך אני יכול לבטל תשובות אוטומטיות של משתמש המערכת?
Hello, currently, I’m creating some topics using the discourse API on our self-hosted discourse instance. These topics are created and updated by the system user, and everything is working properly, however, every time I update the topic using this user, this automatically generates a new post on the topic with the changes that have occurred.
Is there a way to disable this behavior?
Hello and welcome @pedroven :slight_smile:
Those particular small action posts are added as part of the create post for category and tag changes admin setting:
If you disable that then they should no longer be generated for category and tag changes. :+1:
Huge Thanks @JammyDodger!
