How to disable Discourse automatic bump for topics
It’s driving my crazy, is there any way to disable the automatic bump on Discourse?
The feature isn’t for me and I have to stop getting the AUTOMATICALLY BUMPED messages.
Thanks,
See Automatically bumping old topics on a category
If you have configured some categories of your site to bump you have to disable the feature from the settings of that category
I have tried that option, but it says that the value needs to be larger than 0.
Thanks,
OK, I think I was editing the wrong settings. Currently it’s set to nothing. I’m setting all them to 0.
I just tried to set Support to 0 and it works
Ah ok!
If the their value are set nothing, I still need to set them to 0?
Thanks,
Nope, in my test site I never activated this function and the category setting is empty.
Thank you so much for your help.
I’m curious, can you explain why you don’t like the automatic bumps?
Because I have a small forum and the notifications under topic are overwhelming. Also, personal preference.
I guess if the system account and the AUTOMATICALLY BUMPED message will stop appearing in the topics it would be a much better feature.
Why don’t you close/delete these topics?
We’re using them here and it has been a tremendous help in closing old topics and/or deleting irrelevant ones.
Well sort of.. opinions vary.
I wish bumps came from someone other than the system user who we could then ignore. (Though I don’t know if that would actually prevent the topics from still being bumped up the topics list to me.)
It would not, so that wouldn’t achieve the goal..
아, @system, 바보야.
