How can I install discourse as forum.example.com with Easyengine, Letsencrypt, Wordpress all together?
Honggi An asks how to install Discourse as forum.example.com using EasyEngine, Let’s Encrypt, and WordPress together. pfaffman suggests using Nginx reverse proxy, referencing guides on configuring Discourse with Nginx and Caddy Server. pfaffman notes that EasyEngine may not support the required setup, recommending running Discourse on a separate server or using CaddyServer for reverse proxying. Honggi expresses gratitude and acknowledges the complexity of the task, thanking pfaffman for the detailed assistance Honggi An.
I use Easyengine for simple web server installation.
Is there any one who is using discourse with Easyengine, Letsencrypt, Wordpress?
I followed many instruction, but I couldn’t find the solution yet.
Sincerely,
Honggi An
Try this: Set up Discourse on a server with existing Apache sites
@pfaffman thank you very much for your help, but I prefer to use nginx(Easyengine) as a server program, so I am looking for nginx based solution. Do you have any other opinion?
It’s essentially the same. You’ll just configure nginx to reverse proxy rather than apache.
Also, you can search for “nginx reverse proxy” and find stuff like: Discourse in Docker + NGINX reverse proxy + SSL everywhere + OAuth2 Custom
@pfaffman Thank you so much for your reply and concern, In my case Discourse is the most useful solution for making wordpress + blog + community, but setting discourse is quite hard for me. Maybe I prefer Easyengine so much, so I am looking for A-Z solution. Thank you so much.
Sincerely,
Honggi An
From what I can tell, EasyEngine is unable to do what is required to allow Discourse to run on the same host: EasyEngine Community Forum. Since EasyEngine doesn’t do what it required, it makes it harder.
The simplest solution would be to run Discourse on a separate server on a subdomain, following the INSTALL-cloud instructions.
The way that I do it is to have CaddyServer do the reverse redirect; you might check Use Caddy instead of NGINX as your reverse proxy.
Dear @pfaffman
Thank you so much for your specific information, I didn’t know it is such hard thing before, also I know caddy server for the first time. I will try my best for solving this issues, and I will contact by e-mail when I need your help. By the way I don’t know you do an activity in here, quite impressed with your activity and reply for my useless question.
Sincerely,
Honggi An
