DiscourseUser is seeking tips to make their Discourse forum resemble Reddit, specifically with a “Reddit Classic” look. They want to add a sidebar, similar to Reddit’s, and have found a potential solution in the Discourse-category-sidebars plugin.
keegan recommends the following plugins to achieve a Reddit-like experience:
Custom Layouts Plugin: allows for adding widgets to sidebars, which can be used to create a Reddit-style sidebar.
Topic List Thumbnails or Topic List Previews: enhance the topic list with thumbnails or previews, respectively.
Question Answer Plugin or Discourse Feature Voting: enable upvoting in a question/answer style format.
So obviously treaded messages won’t happen, but that is completely fine.
However, I’m looking for tips, how to make a Discourse forum as “Reddit like” as possible, with “Reddit Classic” look in mind.
For example, I want to have a sidebar like reddit does, I figure this one might be the best bet: Topic List Sidebars
Does anyone have any tips for other potential plugins?
For sidebars take a look at the Custom Layouts Plugin which creates a framework for adding widgets to sidebars. Then you can any of the available widgets into either the left and/or the right sidebars to make it look more reddit-like.
