How can I see the posts of a deactivated user?
The original poster, dandv, deactivated a user due to suspicious posts and now wants to delete those posts. However, as an admin, dandv is unable to access the user’s posts or profile since the user is deactivated. The suggested workaround is to temporarily reactivate the user to access their profile or search for their posts. dandv proposes a feature suggestion: adding a “Show all posts” button or hyperlinking the post count to a search for the user’s posts, allowing easier access to a deactivated user’s content.
I’ve deactivated a user because one of their posts had a questionable link, and since I had migrated the forum anyway, they should use Forget password to recover their account.
Now after finding another post of that user that is also questionable, I’ve concluded that the user was a paid spammer, and would like to delete their posts. Problem is, I can’t do quite do that:
Can’t delete all posts. Some posts are older than 60 days old.
  • There’s no “Show Public Profile” button.
Suggestion: hyperlink the number of posts to a search for posts by that user, or have a “Show all posts” button. The search does work, even with the user disabled.
Workaround: temporarily activate the user to get Show Public Profile back, or search by user; both relatively counter-intuitive or cumbersome.
「いいね!」 3
