Hello,
Is it possible to disable private messages between non Admin or moderator users?
Thanks,
Ricardo
Hello,
Thanks,
Ricardo
No need for all this conversation, there is a single Boolean in site settings that does what you want. “Enable private messages”. Seems obvious enough to me..
But this would also disable private messages between a moderator / admin and user?
Nope, it will not. Staff are always immune from these kinds of restrictions.
This is Awesome! Thanks.
I should change the copy for this setting to be more clear…
Hmmmm, I’m missing seeing that in the guardian.rb file.
def can_send_private_message?(target)
(target.is_a?(Group) || target.is_a?(User)) &&
# User is authenticated
authenticated? &&
# Can't send message to yourself
is_not_me?(target) &&
# Have to be a basic level at least
@user.has_trust_level?(TrustLevel[1]) &&
# PMs are enabled
(SiteSetting.enable_private_messages ||
@user.username == SiteSetting.site_contact_username ||
@user == Discourse.system_user) &&
# Can't send PMs to suspended users
(is_staff? || target.is_a?(Group) || !target.suspended?)
I don’t want to over-step, especially since I don’t know if the changes would have ramifications elsewhere and only did minor testing. .
But as best as I can tell, this seems to work more in tune with the stated intent
authenticated? &&
- @user.has_trust_level?(TrustLevel[1]) &&
+ (@user.has_trust_level?(TrustLevel[1]) || is_staff?) &&
# PMs are enabled
- @user == Discourse.system_user ) &&
+ @user == Discourse.system_user ||
+ is_staff?) &&
You were right about the bug here @Mittineague. Should be fixed now:
https://github.com/discourse/discourse/commit/b32f33b3f06602e1d742920b8024949aaaa647b2
