Allow sending Private Messages to Staff
I have a client who wants to have people send a form with some information on it. No problem, just Creating pre-filled personal message links!
But this client also wants to disable private messages for at least most users, so that won’t work. (I tried :frowning:)
One solution would be a site setting that would allow users to be able to send PMs to staff.
Perhaps I’m missing something, bu tI’m afraid the other solutions all require a plugin or some other app. (e.g., Canned replies works only for staff, right?)
3 „Gefällt mir“
Why does this form need to be in Discourse? Just create a Google Docs form or something.
Yeah. That was my idea too. Crazy guy just doesn’t want to leave Discourse.
I’ve got two clients right now who are itching to do everything in Discourse and not have WordPress/Drupal/Squarespace to handle other stuff.
1 „Gefällt mir“
Right but at the point when you’re contorting the system into a :pretzel: maybe a simple Google Docs form would be better?
1 „Gefällt mir“
If I’m reading you right, you want to restrict the target of pms to staff only?
You could do this relatively easily in a standalone plugin. The plugin.rb would read:
# name: only-pms-to-staff
# about: You can only send pms to staff
# version: 0.1
# authors: pfaffman
after_initialize do
  add_to_class('guardian', :can_send_private_message?) do |target|
    target.is_a?(User) &&
    # User is authenticated
    authenticated? &&
    # Have to be a basic level at least
    @user.has_trust_level?(SiteSetting.min_trust_to_send_messages) &&
    # User disabled private message
    (is_staff? || target.user_option.allow_private_messages) &&
    # PMs are enabled
    (is_staff? || SiteSetting.enable_private_messages) &&
    # Can only send pms to staff
    target.staff?
The original method is here.
See also: How do disable private messages between non staff users? - #10 by Mittineague
11 „Gefällt mir“
Thanks, @angus!
Here’s what I ended up with. If I were better at understanding the distributed properties of and and or, I’d have moved target.staff? outside of those three expressions, but this seems to do what I wanted. My scant tests show that it allows sending to an admin and if you send to an admin and another user, it is denied.
after_initialize do
      authenticated? &&
      (target.staff? || @user.has_trust_level?(SiteSetting.min_trust_to_send_messages)) &&
      (target.staff? || is_staff? || target.user_option.allow_private_messages) &&
      # PMs are enabled
      (target.staff? || is_staff? || SiteSetting.enable_private_messages)
it doesn’t quite meet my standards for posting to #plugins just yet, but if anyone stumbles here and wants to do this, here’s this:
https://github.com/pfaffman/discourse-allow-pm-to-staff
10 „Gefällt mir“
On the face of it, these changes allow:
  1. Any user who has the min trust level to send a pm, to send a message to any other user who has not disabled pms, regardless of whether or not they are staff.
    The issue is this line:
    The first alternative, i.e. target.staff?, is redundant, as the last alternative will always be true as long as pms are turned on.
    The is_staff? check here is used to ensure that staff members can still perform an action even if that action is disabled (this is normal practice in the Discourse code). Keep those two as the only alternatives in that line, i.e.
    There was an issue with my initial code, as it didn’t allow staff members to send messages to non-staff members. The way to fix that is by adding the is_staff? check to that line specifically, i.e.
    (is_staff? || target.staff)
  2. Any user of any trust level to send a message to a staff member (e.g. immediately after joining).
    This means that if the target is a staff member you don’t need the min trust level. Probably best to require the min trust level for all messages.
  3. If a staff member has specifically dis-allowed pms to be sent to them, you will still be able to send pms to them.
    Unless you want pms to reach staff members even if they have specifically disabled them, remove target.staff? from this check.
9 „Gefällt mir“
First, I really appreciate your help.
But that didn’t seem to be the case, when I tested. I even tested sending to a staff and a non-staff person in a single message and it was rejected.
The way I read that, it’s
  • the receiver is staff OR
  • the sender is staff OR
  • private messages are enabled (and they’re not for this site, which is what I’m trying to solve)
And I (or this client) want everyone to be able to send to staff.
Hooray! That’s what I wanted! :tada: (Of course, it could prove to be a problem, but we can solve it when there is one) It’s good advice to change that to TL1, though. I made a note of that too.
Ah, that’s (but one of the reasons) why I don’t think anyone should use this. For this site, I’m sure that no staff will be disallowing PMs. I should probably fix this one. I added a comment to remind me to do so when I can “test” – not to be confused with writing a proper test! (Or maybe I want to make sure that a staff member who needs to receive these messages doesn’t inadvertently disable PMs :slight_smile: – A documented bug is a feature!)
Thanks again, @angus! A couple more trivial plugins under my belt and I might do something useful!
5 „Gefällt mir“
Ah, I had assumed you were going to keep the site setting on. That change in logic makes a bit more sense now :slight_smile:
However, I think you may want to keep the site setting on and restrict pms just via the guardian though. If the site setting is off this will also:
  1. Disable message-related elements in the UI, specifically the messages icon in the user menu will not appear and the private messages button will not appear in the user profile.
  2. Prevent the user from taking the notify_user and notify_moderator post actions (see here). These post actions require private messages.
And there may be more instances of that setting being used to disable functionality in the future.
If I’m reading you right, your case is one of permissions, not one of functionality? You still want the functionality, just a restricted version of it.
edit: re-reading your first post, maybe you do want to disable the functionality entirely! Well at least we thought this through.
7 „Gefällt mir“
This is how my naive solution is so lucky! The plan is to use a URL to generate the initial message, so not being able to see the PM interface is a bonus!
That’s pretty fine too, as this is basically doing the same thing as using a Google form would be. It’s mostly for a one-way initiation of a conversation. I should check what happens if someone replies to the PM, though.
Ah, yes. The Royal “We”. Thanks very much for your help. You’ve taught me a lot and I appreciate it.
3 „Gefällt mir“
Hast du dafür jemals eine Lösung gefunden, Jay?
Ich habe ein ähnliches Problem, das sich sehr elegant lösen ließe, indem man normale 1:1-PMs verhindert. Es handelt sich um eine Freiwilligenorganisation, und die Freiwilligen müssen mit den Koordinatoren kommunizieren können, aber idealerweise nicht untereinander.
4 „Gefällt mir“
Das oben erwähnte Plugin (https://github.com/pfaffman/discourse-allow-pm-to-staff) funktioniert. Ich mache keine Versprechen, aber der Auftraggeber, der es entwickelt hat, nutzt es weiterhin, sodass es aktiv gewartet wird und sogar Tests enthält, die auf Travis ausgeführt werden.
4 „Gefällt mir“
Danke für den Beitrag, @pfaffman und @angus!
Ist es bei dir schon mal funktioniert, @Stephen?
Ich verstehe, dass dies kostenlos und ohne Zusagen bereitgestellt wurde – was wirklich sehr geschätzt wird. :slight_smile:
Kurz als Hinweis: Es scheint aktuell nicht zu funktionieren. Sofern ich nichts falsch konfiguriert habe, ist das Plugin installiert und aktiviert.
Ich habe es getestet, indem ich „Minimales Vertrauensniveau zum Senden von Nachrichten
2 „Gefällt mir“
Nun, es scheint auf meiner Dev-Instanz mit 2.6.0.beta1 und auch auf einer Produktionsinstanz mit 2.5.0.beta4 zu funktionieren, und die Tests bei Travis bestehen weiterhin.
Meine einzige Vermutung ist, dass es bei Multisite nicht funktioniert und du Multisite verwendest?
2 „Gefällt mir“
Das ist großartig zu hören, dass es funktioniert! Vielleicht übersehe ich etwas Offensichtliches. Dies betraf keine Multisite-Installationen, sondern ganz normale Docker-Installationen.
Die durchgeführten Schritte waren:
  • Installation des Plugins von https://github.com/pfaffman/discourse-allow-pm-to-staff.git. Ich habe dieses Plugin nicht explizit aktiviert oder plattformspezifische Optionen festgelegt. In /admin/plugins wird jedoch bei ‘enabled?’ ein ‘Y’ angezeigt.
  • Anpassung der Einstellung ‘Mindestvertrauensstufe zum Senden von Nachrichten’ und Test mit einem regulären Benutzerkonto, das unter diese ausgewählte Vertrauensstufe (TL) fällt, indem versucht wurde, Mitarbeiter zu kontaktieren.
  • Versuch, alle Plugins außer diesem auf der stabilen Version 2.5.0 zu entfernen, falls es zu einem Konflikt käme, aber dies brachte keine Änderung.
1 „Gefällt mir“
Habe herausgefunden, was das Problem war :partying_face:
Ich habe die Travis-Tests nicht angepasst/konfiguriert, was anscheinend verhindert hat, dass das Plugin funktioniert.
Also habe ich versucht, alles außer der Datei plugin.rb zu entfernen, und es hat für mich funktioniert. Ich habe die Logik auch leicht an meinen Anwendungsfall angepasst.
Aktuell können Benutzer mit Vertrauensstufe TL0+ einen Administrator kontaktieren, wenn ihr Vertrauensniveau unter die konfigurierte „minimale Vertrauensstufe zum Senden von Nachrichten
2 „Gefällt mir“
Das ist seltsam. Ich weiß nicht, wie das möglich sein könnte.
1 „Gefällt mir“
