Comment désactiver complètement onebox ?
It would be nice if you would add an explanation on how to disable onebox completely. At least with Discourse 2.5.0.beta6 disabling it via “max oneboxes per post = 0” doesn’t work.
1 « J'aime »
Are you sure? can you include an example of raw text of a post with a onebox that is not respecting the setting? You may be looking at something that is not a onebox.
3 « J'aime »
Hi Sam,
thx for responding so quickly!
Here’s the text of the post (at least 2 links, I’m not allowed to post more):
I guess the video is not a onebox, but the second one.
2 « J'aime »
You can find the post here:
1 « J'aime »
I cannot repro this issue locally. Setting max oneboxes per post to 0 disables onebox for me completely, even as an Admin user.
8 « J'aime »
Thx for trying to reproduce this issue! It’s strange but after some time it was working in our installation aswell – as if there was a delay. Anyways, problem solved! :slight_smile: Have a nice day!
2 « J'aime »
