For example i would like to insert a optinmonster Optin. This should be the code:
<!-- This site is converting visitors into subscribers and customers with OptinMonster - http://optinmonster.com -->
<div id="om-o1ozq0it5dg9dp9v-holder"></div>
<script>
var o1ozq0it5dg9dp9v,o1ozq0it5dg9dp9v_poll=function(){var r=0;return function(n,l){clearInterval(r),r=setInterval(n,l)}}();!function(e,t,n){if(e.getElementById(n)){o1ozq0it5dg9dp9v_poll(function(){if(window['om_loaded']){if(!o1ozq0it5dg9dp9v){o1ozq0it5dg9dp9v=new OptinMonsterApp();return o1ozq0it5dg9dp9v.init({u:"17705.331160",staging:0,dev:0,beta:0});}}},25);return;}var d=false,o=e.createElement(t);o.id=n,o.src="//a.optnmnstr.com/app/js/api.min.js",o.onload=o.onreadystatechange=function(){if(!d){if(!this.readyState||this.readyState==="loaded"||this.readyState==="complete"){try{d=om_loaded=true;o1ozq0it5dg9dp9v=new OptinMonsterApp();o1ozq0it5dg9dp9v.init({u:"17705.331160",staging:0,dev:0,beta:0});o.onload=o.onreadystatechange=null;}catch(t){}}}};(document.getElementsByTagName("head")[0]||document.documentElement).appendChild(o)}(document,"script","omapi-script");
</script>
<!-- / OptinMonster -->
If i paste it into a topic it won’t show. Is there a way to make it work natively?
