Como fazer o Typeform incorporar no onebox?
As the question suggests, curious how I can get a Typeform survey to embed like it’s shown here.
Is this plugin related or am I missing something? Currently only pasting the link doesn’t do the trick.
Typeform oneboxes are supported by default, and have been for over two years now per
I just tested this and didn’t encounter any issues.
Did you add the link on a separate line?
External oneboxes, like typeform only work if the link is on its own line.
If not, can you try that?
If you do and it still doesn’t work, can you share a link to an example form/survey that you’re having trouble with?
It worked, thank you!
