ما مدى سهولة الانتقال إلى خادم آخر؟
أحتاج فقط إلى تثبيت Discourse جديد على الاستضافة الجديدة، وتثبيت النطاق، ثم رفع النسخة الاحتياطية؟
4 إعجابات
The moving process goes like this:
  1. Put forum in Read Only
  2. Take a Backup & Download it
  3. Point domain to the new Server
  4. Install and set up discourse on new server
  5. Restore Backup
12 إعجابًا
Note that you can also restore backup from the command line if you wish to skip the setup wizard and initial configuration with the web browser, as well.
8 إعجابات
How do I do it from the command line?
إعجاب واحد (1)
There is a howto topic for this. :mag: search here is super useful.
10 إعجابات
Thanks, I can see that anyway you need to rebuild the application so it comes out with same time for work with i.
Are there any benefits of this solution?
