كم من الوقت يستغرق تجميع نسخة مشتقة من صورة discourse Docker؟
Since non-docker installs are not supported and apparently difficult to install, I’m wondering how long does it take to compile a fork of your docker image? Is it possible to re-use the discourse/base build and to swap in discourse/discourse? I ask because I might want to experiment with making changes to a future instance of discourse.
Thanks! :slight_smile:
That depends on how fast your computer is. :wink:
We build the discourse/base image on an Optimized Droplet (8 GB, 4 vCPUs) at DigitalOcean and it takes about 40 minutes.
إعجابَين (2)
