Installed Discourse in 30 minutes with no prior knowledge
Users praise the ease of installing Discourse, with several reporting success in under 30 minutes—even as complete beginners. gerald credits the official guide for helping him set up a self-hosted instance despite initial fears of SSH and Droplet configuration. codinghorror acknowledges the guide’s solid foundation, originally started by @techapj. icaria36 relates to this experience, noting it took them 45 minutes after troubleshooting mail and Let’s Encrypt, and points out that Digital Ocean offers preinstalled Discourse droplets—though not mentioned in the guide. schungx reminds users that ongoing server management (updates, patches, security) still requires Linux knowledge. codinghorror explains the $20/month droplet requirement for preinstalled Discourse is due to Digital Ocean’s swap configuration rules, though Discourse runs well on $10/month plans. Anil_Gupta highlights the speed and simplicity of the official Docker install on Google Compute Engine (~15 minutes), contrasting it with Bitnami’s older version (v1.8.10) and lack of easy upgrades. He documents migration challenges—like PostgreSQL version mismatch (9.6.5 vs 9.5) and the need to comment out unsupported parameters in backup SQL files—sharing a detailed guide. gok4 recounts a 2-day setup for an NGO using Digital Ocean’s one-click install, appreciating the docs despite the learning curve. Overall, users celebrate Discourse’s accessibility while acknowledging some technical hurdles remain for advanced configurations.
Hey,
Wanted to send big thanks to the devs, i was initially scared of all the ssh stuff and the Droplet configuration, but i followed the official guide and set up a self hosted Discourse in 30 minutes.
I have little idea what i actually did there, but bottom line it works :slight_smile:
Thanks!
26 Me gusta
Nice! Glad to hear the install guide is still solid, it was originally started by @techapj.
7 Me gusta
As a total newbie I can relate to @gerald, even if it took me a bit longer (45 minutes or so, after finding simpler ways to fix mail and LetsEncrypt configuration, also in this forum).
Then a couple weeks later I learned that Digital Ocean offers droplets with Discourse preinstalled, a detail not mentioned in the guide even when it assumes Digital Ocean as ISP… :face_with_raised_eyebrow::smirk:
Don’t forget you can’t skip the occasional server management tasks though… upgrades and patches and general security fixes. You’ll still need somebody who knows a bit Linux.
1 me gusta
That’s because it forces you into the $20/month droplet due to their rules around not configuring swap. It’s not ideal, since Discourse works just great in the $10/month droplet.
7 Me gusta
The instructions are really easy and installation is fast.
I installed it on Google Computer Engine and I guess it took only about 15 minutes or so from start to end.
Thumbs up to the team.
Note:
I initially used Bitnami Discourse image which was running discourse v1.8.10. There was no easy one click upgrade available with Bitnami image.
So, it prompted me to try the official Docker Discourse install.
The newest install seems faster than bitnami image install. Not sure if this is due to the most recent version or Bitnami’s install has some other baggage attached to it.
Issues found while moving from Bitnami image to official Discourse Docker:
  1. Bitnami image uses postgresql version 9.6.5 at this time but Discourse docker is still on 9.5.
  2. While moving with Discourse’s back up restore utility, I got this error from postgresql:
ERROR: unrecognized configuration parameter “idle_in_transaction_session_timeout”
The solution is to modify the sql file that is created by Discourse back up (from postgresql 9.6.5 bitnami image) and comment the line using this variable. This variable was introduced in postgresql 9.6.
I have documented the Move bitnami discourse install to official Discourse docker install, if anybody is looking for it.
7 Me gusta
I was setting up discourse for an NGO & it took me about 2 days to set it up with ssl using digital ocean one click install droplet. It took me some time to go through all the docs, somehow I managed to set it up.
Thanks!
1 me gusta
