I want to add a topic to a top menu but not on all categories, just a specific one.
What code should I write?
Thanks
Found those topics but none of them was for a specific category…
https://meta.discourse.org/t/how-to-add-external-link-on-top-menu/9508/6
https://meta.discourse.org/t/best-way-to-customize-top-menu/35336
Tested this solution a bit more (modified from this post) try this (replace “Travel” with your category name):
<script>
Discourse.ExternalNavItem = Discourse.NavItem.extend({
href : function() {
return this.get('href');
}.property('href')
I18n.translations.en.js.filters.bugs = { title: "Bugs", help: "Open Bugs" };
I18n.translations.en.js.filters.google = { title: "Google", help: "Navigate to Google" };
Discourse.NavItem.reopenClass({
buildList : function(category, args) {
var list = this._super(category, args);
if(category && category.name == "Travel") {
list.push(Discourse.ExternalNavItem.create({href: '/category/bug', name: 'bugs'}));
list.push(Discourse.ExternalNavItem.create({href: 'https://google.com', name: 'google'}));
return list;
</script>
I18n.translations.en.js.filters.bugs = { title: “Bugs”, help: “Open Bugs” };
I18n.translations.en.js.filters.google = { title: “Google”, help: “Navigate to Google” };
Those are for English-based forums…
Your forum is French, so use I18n.translations.fr instead.
Still the same thing with translations.fr
<script>
href : function() {
}.property('href')
I18n.translations.fr.js.filters.liste = { title: "Liste", help: "Liste des formations" };
if(category && category.name == "Formations") {
list.push(Discourse.ExternalNavItem.create({href: '/t/liste-2-0-des-formations-sur-lautosuffisance-et-la-consommation-ecoresponsable-en-2018/306', name: 'Liste'}));
return list;
</script>
Try name: 'liste'instead
¿De dónde ha salido ese precioso calendario??
Esto parece dejar de funcionar tras la deprecación de Discourse.NavItem, y alguien mencionó en este post que Enlaces personalizados de navegación superior pueden resolver el problema:
Sin embargo, este componente no genera enlaces dinámicos según la ubicación actual para verificar la URL del enlace.
Para mi caso de uso, quiero establecer un enlace diferente para la página principal y las subcategorías, por ejemplo, mostrar un elemento de navegación con filtro de etiquetas incompleto/completado según las categorías actuales. Anteriormente podía usar el siguiente código, pero ahora no funciona:
<script>
href : function() {
}.property('href')
I18n.translations.en.js.filters.unfinished = { title: "tbc", help: "placeholder" };
I18n.translations.en.js.filters.finished = { title: "finished", help: "placeholder" };
var url = category ? category.url : "";
// El menú principal y 2 categorías específicas tendrán esos 2 elementos de navegación con URL diferentes
if(!category || (category && url && (url.includes("mix") || url.includes("other")))) {
var tbc_url = category ? "/tags" + url + "/tbc" : "/tags/tbc";
var finish_url = category ? "/tags" + url + "/finished" : "/tags/finished";
list.push(Discourse.ExternalNavItem.create({href: tbc_url, name: 'tbc'}));
list.push(Discourse.ExternalNavItem.create({href: finish_url, name: 'finish'}));
return list;
</script>
¿Alguien puede ayudarme a actualizar este código basándose en el componente navigation-item actual? O, como pregunta más general, ¿cómo puedo encontrar el uso actual del reemplazo de Discourse.NavItem?
¡Gracias!
¿Aún funciona? No funcionó cuando lo probé, ¿deberíamos añadir una versión de complemento?
