How can I add add helpers for a connector in templates folder for an outlet?
This is a year old and I haven’t revisited it since so be warned YMMV.
In plugin.rb I registered the helper file.
register_asset "javascripts/helpers/post-image-links.js.es6"
* may not be necessary, as “es6” files are auto-magically included.
The es6 helper file had the script stuff
Ember.Handlebars.helper('post-image-links', function(param) {
var output = " ";
â‹®
return output;
and the connector hbs
{{#if Discourse.SiteSettings.post_image_links_active}}
<div class="post-image-links">
{{#if cooked}}
{{#if (post-image-links) }}
{{{ post-image-links cooked }}}
{{/if}}
{{/if}}
</div>
{{/if}}
which went into a hacked post.hbs file
â‹®
<div class='cooked'>
{{{cooked}}}
{{plugin-outlet "in-cooked"}}
{{#if firstPost}}
{{plugin-outlet "topic-after-cooked"}}
{{/if}}
</div>
â‹®
