How to always show sidebar as menu panel?
On a community I’ve enabled the sidebar and adjusted the panel view like that:
I’d always like to use that panel menu and not switch between panel and sidebar depending on view-width. Is there a simple declaration to achieve that?
Right now, it is not easily configurable via SiteSetting.
Behavior is controller by NarrowDesktop
The potential solution would be to create a plugin which would overwrite isNarrowDesktopView function to always return true.
Something like initializers/always-narrow-view.js
import NarrowDesktop from "discourse/lib/narrow-desktop";
export default {
  initialize(container) {
    NarrowDesktop.isNarrowDesktopView = () => true;
Thank you Kris!! :sunny:
I wrapped it in a theme component and so far seems to work like a charm :sparkles:
Will play around and test it a bit more still..
So I love how this works for full-page layouts, offering a generous sidebar menu without breaking the layout:
Unfortunately I realized it also changes the user-menu to always slide-in. That’s not such a good experience. I guess it will get more complicated to de-couple the behavior?
As a side-note, I saw that the user menu panel has the classes:
.user-menu.revamped.menu-panel.slide-in
But the sidebar menu panel only has the classes:
I think it could be helpful to have a dedicated class .sidebar-menu there as well.
