How to change font colour
Hi community,
i´m new on discourse.
Is it possible to change the font colour in a posting?
If that is possible via code or something like that, can you tell me, where i can find is list/thread with the most popular codes?
Regards, Heiko
Not unless the site owner has the BBCode plugin installed, no.
Hi @codinghorror,
ok, thank you for your answer.
I will inform our admin, about this plugin.
Regards, Heiko
Check requirements but if your discourse qualifies/ meets requirements. Procourse plugin is great for installing plugins.
