How to change header background color
I want to change the site header background color from grey to orange,
I understand that I need to use CSS but I am unaware of how.
All contributions appriciated, thanks.
if you go to yourdomain.com/admin/customize/colors
you can use the existing pallette or create a new one to change your colors.
example:
Thanks Gavin.
Hope you are doing well.
