So ändern Sie den Themenfortschritt
Hi! Ask how to change the time bar of this post to this style?
import tn from 'discourse/components/topic-navigation';
export default {
  initialize: function(){
    /* This is mostly the same code as in the current _performCheckSize()
       function, but "forced" to use the mobile-style indicator and pop-up
       timeline menu rather than the floating one.
       This code will need to be updated any time the topic-navigation
       component in Discourse receives major changes.
    tn.reopen({
      _performCheckSize() {
        if (!this.element || this.isDestroying || this.isDestroyed) { return; }
        let info = this.get('info');
        if (info.get('topicProgressExpanded')) {
          info.setProperties({
            renderTimeline: true,
            renderAdminMenuButton: true
        } else {
            renderTimeline: false,
I tried the above code, but the style came out like this.
