Since docker 1.10 it’s possible to set a static IP address for docker containers. This is useful when you have a nginx instance managing a lot of sites.
I guess one should edit the .yml
file, but I’m not sure how
You should use links, rather than hard-coded IPs, to refer to other containers.
But I need to refer to a container from the actual host, not from another container, how could links help?
We have --docker-args
args for that these days you can append whatever docker arguments you want to ./launcher
