Linking containers for a multiple container setup
Multiple Container setup
If you would like to connect web-only and data Discourse docker containers.
There is optional setting for this, which is, you could specify a links key in container configuration (yaml file) to link those containers together ( i.e. linking web-only and data container ).
This way is also known as Docker --link flag.
Usage:
If you are trying to link database container to your web container
Add the following section in containers/web.yml
links:
  - link:
      alias: db
That will be transformed into --link data:db
I’ve been trying this approach, as I’m familiar with using --link and found this in the web-only config, but then what are you supposed to indicate for DISCOURSE_DB_HOST/REDIS_HOST etc? db:migrate keeps failing on bootstrap for me, even though the data container is already running!
Maybe Use multiple Docker containers without exposing ports is what you are looking for, i.e. if you link to the data container then both DISCOURSE_DB_HOST and DISCOURSE_REDIS_HOST should both be set to data
