Hello, community,
we are looking for a solution to create an in-app widget with Knowledge Base.
Like this
https://userpilot.com/blog/help-center-widget/
Or
We want to create a KB using Discourse Docs and then link it with an in-app widget.
Does anyone know of a solution to achieve this please?
Thank you
Petr
2 לייקים
Hi Petr! Welcome. The first link you shared appears to have a table of contents linking to headings within the page. This is something you can achieve with DiscoTOC - automatic table of contents.
The second screenshot is of search, which Discourse does very wel! Try it out here on meta, by selecting the
in top right corner.
I’m not quite sure what you mean by “link it in with an in-app widget”. Can you explain in some more detail?
3 לייקים
Hi Tobias,
thank you for your reply.
I found the widget right for Discourse. But we need the widget on our external domain.
Explain
We run a SaaS and we want to add instant Help using a floating widget. The user clicks on the widget and the help links /articles are displayed. Like here Develop custom experiences with the Zendesk Platform | Zendesk Sunshine You can see animation how it should works.
(This is a common way of displaying help in SaaS projects.)
The KnowledgeBase we want to make by Discourse Docs. Like this Documentation - Discourse Meta
So we are looking for a solution for the widget that can display relevant results from our Discourse Docs KB.
לייק 1
