Hoe pas ik het uiterlijk van discourse embeds aan?
kirupa is seeking to customize the appearance of Discourse embeds to match the dark mode of the parent site. The embed is iframed, which limits style sharing. kirupa also wants to retain code syntax highlighting in the embed.
JammyDodger suggested a potential solution for auto-dark embeds, while weallwegot provided CSS pointers from a related thread. kirupa plans to try customizing CSS via the suggested approach.
Hi everyone,
I use the discourse embed feature to surface posts on a non-discourse site. When I have dark mode on the main site enabled, I would like to style the discourse embeds to appear appropriately as well:
Is there a way for me to have the embedded instance inherit the styles from the parent page? I believe it is iframed right now, and that is limiting style sharing.
Thanks,
Kirupa
Another thing is that the code syntax highlighting is also missing. Is there a way to make the embed look more natural with the site it is being displayed in while also retaining syntax highlighting? :slight_smile:
I think the auto-dark embeds has cropped up before if this is any use:
And as another potential helpful thread there are a few CSS pointers here, though I haven’t done it myself:
Thanks so much for the suggestions! I’ll try setting custom CSS via the approach you have described :slight_smile:
