How to delete thousands of Private Messages?
Our community has several thousand private messages that have been sent between users. Is there a way to completely remove private messages with more than 100 replies from the database (without recovery)?
Well, I think that this will do what you asked. It will delete any private messages that were not created by a system user or discobot. It will still delete any other private messages, including those from admins.
It’s not tested. I’m not saying that it’s a good idea. I won’t promise that it won’t do something bad.
cd /var/discourse
discourse backup
./launcher enter app
rails s
Topic.where(archetype: 'private_message').where("user_id > 0").destroy_all
exit
discourse enable_restore
discourse restore
If something bad does not happen, you can omit the last two steps. If something bad does happen, you’ll want to copy/paste the most recent backup printed by the discourse restore command to restore the backup.
You can remove all message at once.
rake destroy:private_messages
Reference:
Nice work, @IAmGav! I swear i looked there and didn’t see.
Thanks Jay,
Running batch delete query directly on the database is so Scary :sweat_smile:
I took a brief look at how this function works. As it turns out, after running it, all private messages will be deleted.
  def destroy_private_messages
    Topic.where(archetype: "private_message").find_each do |pm|
      @io.puts "Destroying #{pm.slug} pm"
      first_post = pm.ordered_posts.first
      @io.puts PostDestroyer.new(Discourse.system_user, first_post).destroy
I think I have to choose the scary way that @pfaffman pointed out to filter messages. or try to define custom rake function and use PostDestroyer.new(Discourse.system_user, first_post).destroy
Revisiting this old topic, since none of the answers are 100% correct.
The rake task rake destroy:private_messages does not hard delete all private messages, it soft deletes them. They can still be seen by an admin and they can be recovered.
The Rails code Topic.where(archetype: 'private_message').where("user_id > 0").destroy_all destroys the topics, but not the actual messages. They are still in the database and can be viewed using for instance the data explorer plugin.
This code will permanently delete all private message posts and topics:
warning: sharp knife here!
Post.where(topic_id: Topic.where(archetype: 'private_message').where("user_id > 0")).destroy_all
(and to filter this on topics with 100 replies or more you need to extend the Topic.where with where("posts_count > 100") in both lines)
