كيفية تعطيل التسجيل الافتراضي والسماح فقط بتسجيل الدخول من جهات خارجية؟
I’m from Mainland China. Because of the 互联网论坛社区服务管理规定, I just want to the users who can connect Google to registration my forum(they can’t use email to registration the forum directly). So, the question is: how can I do that?
Thanks.
You can disable the “enable local logins” option, which will force users to use other enabled login methods.
