How to disable Incoming Email modal
How should I make this email icon nonclickable?
How should I disable this Incoming Email model?
Screenshot 2023-11-28 233500
And how to disable this
Today I Learned that that icon is clickable.
Haha yea, it is, annoying :laughing:
Btw Happy Birthday :grin: :star2:
I suspect it’s staff only, just checked on a forum where I don’t have staff, and I cannot click on the icon. (on my phone at least)
Thanks! (though that’s partially timezones, it’s not my birthday here yet :upside_down_face:)
I have to see this, thanks for telling me about it. :grinning:
Here It shows a cake icon next to your name haha anyway happy birthday in advance I guess I am the first one to say this :joy:
Aa it is only visible to admins so no issues with it.
Anyways, if anyone else like me wants to disable this but can’t find a way here what I did with GPT and it worked great :slight_smile:
  api.onPageChange((url, title) => {
    // Wait for the page to fully load
    Ember.run.scheduleOnce('afterRender', function() {
      // Find and remove all details elements with class "elided"
      var elidedDetailsList = document.querySelectorAll('details.elided');
      elidedDetailsList.forEach(function(elidedDetails) {
        elidedDetails.remove();
</script>
Hi kynic,
onPageChange might be a little too broad for usage (and unreliable if you load/update posts).
You can use decorateCookedElement instead. It’s called for every post-cooked element.
Additionally, here is a way to disable the email indicator. It’s just some hack to not include the HTML. If you are curious, you can see the original code here.
    api.reopenWidget("post-meta-data", {
        html(attrs) {
            if (!attrs.via_email) {
                return this._super(attrs);
            // Do not generate "post-email-indicator" widget.
            attrs.via_email = false;
            const html = this._super(attrs);
            attrs.via_email = true;
            return html;
    api.decorateCookedElement((element, helper) => {
        if (helper?.getModel().via_email) {
            element.querySelector('details.elided').remove();
    }, { onlyStream: true });
</script>
You could also use CSS only to hide them.
.post-info.via-email,
.cooked details.elided {
    display: none;
Thanks :grinning:
I removed the post metadata part as I want this email icon to be shown. :slight_smile:
This is what I am using now to remove the content and hide it via CSS just in case.
</script>
    display: none;
Thank you for this code :rocket: :blush:
You’re welcome :slight_smile:
Also, you’re right; only staff can click on the icon! My bad. :smile:
Nice work :slight_smile:
