كيفية تعطيل هذه النصيحة عند نشر موضوع لأول مرة؟
Hi, all
This tip hides the topic preview, which is important for a newbie that post a topic for the first time. Can I disable it?
Thanks
Have you read what the tip says? It’s there specifically for new users and only appears on their first two posts.
Top right there’s a cross they can use to dismiss it, similarly as indicated it will also disappear when they tap escape on the keyboard.
Yeah I have read it and understand it. Just want to know whether I can turn it off ?
im interesed too, thanks ! any advice?
Just use CSS, find the class of the popup, write a theme component that hides it if you wish.
